Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
wtb: pcb screw-type ground point
Old 2nd October 2007, 03:55 AM   #1
PM650 is offline PM650  United States
Default wtb: pcb screw-type ground point
I'm looking for a star shaped through-hole component for a sizeable power supply using screw terminal caps. The pcb I am using for the the supply is not double sided, so I need some way to connect them to the pcb (preferably w/o wires). These are used as a star ground in yamaha amps; see pic atattched: Click the image to open in full size.
Old 2nd October 2007, 06:55 AM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I have never seen anything like that, it may well be a custom part. Still, it could be easily made with a piece of copper sheet and a pair of small tin snips.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 2nd October 2007, 07:11 AM   #3
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
That stuff used to be standard production but is likely outdated and hard to find.
Taking Al's advice and diy something similar is easier and mucho sturdier, the ones i've seen were shabby tin can stuff that look like remnants of 70s Japanese and old school tube amps.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 5th October 2007, 07:07 AM   #4
OzMikeH is offline OzMikeH  Australia
solder 1mm pins in all of the holes then use those 8 of those ring lugs of similar shape to those used for RCA socket grounds connections.
Old 9th October 2007, 01:53 AM   #5
TwoSpoons is offline TwoSpoons  New Zealand
TwoSpoons's Avatar
Make one, using brass or copper sheet, with standard PCB etching techiques. You can then make any shape you want, easily, and it will be flat (unlike trying to use snips). Easiest is to completely mask one side of the metal sheet, and draw your pattern on the other side, then etch with your preferred etchant (Ferric Chloride and Ammonium Persulphate will both work with brass or copper).
I've made all sorts of horribly complicated sheet metal shapes this way (shields, springs, even a solder paste stencil!).
Old 10th October 2007, 03:39 AM   #6
This application isn't exactly critical, so I've decided to use a few of these instead (though not as many as I would like, they're $0.16 each!).
wtb: pcb screw-type ground pointHide this!Advertise here!
Ground point for HF decoupling cap? Jeb-D. Tubes / Valves 1 30th March 2007 08:20 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
