Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
what source selector rotary switch and how to wire it
Old 27th September 2007, 08:05 PM   #1
bemoth is offline bemoth  Sweden
Default what source selector rotary switch and how to wire it
Hello, this have probably been asked several times before but my searches yeilded nothing that realy helped me.
i have some problems. i want to have a swich so i can change source but i dont realy know what switch to use(so super expensive stuff thanx) i want to be able to select three different sources how manny poles resp pos do i need the rotary switch to have?
and after looking att one just now i realised i have no idea what so ever how to wire it
Old 28th September 2007, 04:08 AM   #2
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I assume that you are going to use the swith to select stereo line level sources before a power amplifer ??
If so, look at www.elfa.se and write 35-490-60 in the "søk felt". This is probaly the cheapest switch you can get.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 28th September 2007, 06:49 AM   #3
yes that is what im looking for, but i still dont know how many poles and poses it should have, 3p3t? 3p4t? its three (all in stereo but maby you figured that out ) line in's that i want to be able to switch between
Old 28th September 2007, 10:13 AM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
probably 4P3T. You get to keep grounds seperate
Old 28th September 2007, 03:05 PM   #5
Jan Dupont's Avatar
If you go for Nordics fine suggestion, the connections on the switch would be like this
Old 29th September 2007, 06:05 AM   #6
Jan Dupont's Avatar
Ok I was tired last evening
Here is the correct way to connect the switch
Old 29th September 2007, 05:20 PM   #7
thanx guys, you realy helped me alot
Old 8th October 2007, 08:20 PM   #8
gychang is offline gychang  United States
Default RCA selector problem
I have a similar problem, I have a 4 selector switch (I think) with 4 outer and one inner row on each half of the switch as can be seen.
on selector set at position 1, A,B and C,D are connected as pictured (measuring from multimeter).
I can not figure out 1) where the wires from RCA input jacks (for selector at position 1) should be connected to.
2) where the common RCA output jacks should be connected?, eventually feeding the amplifier.
I would appreciate any help from the experts for this newbie.
gychang
Old 9th October 2007, 03:27 AM   #9
Jan Dupont's Avatar
Connect your inputs to the outer rows (eg. right channel to A and the three pins going left on the outer row and left channel to D and three right) and connect B to right channel input and C to left input of your preamp
Old 9th October 2007, 11:30 AM   #10
right channel (red) from input 1 (2 leads) both are combined and soldered to A?
will try this today. thanks,
gychang
what source selector rotary switch and how to wire itHide this!Advertise here!
Fotios need help with input selector. Rotary switch or Relays? fotios Solid State 49 26th December 2010 12:31 PM
where to source rotary switch? - 3pole-3position gychang Parts 5 17th July 2009 05:27 PM
Wiring a rotary selector switch toolkit Everything Else 13 10th January 2007 07:39 PM
USA source for rotary spst switch? riotubes Parts 11 22nd October 2006 02:52 AM
wtb (or trade): 4 position rotary selector switch erimille Swap Meet 0 27th July 2004 01:54 PM
Copyright ©1999-2017 diyAudio
