Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th September 2007, 07:02 PM   #1
jev is offline jev  Netherlands
Default Car battery, good idea?
I have several boxes that work on 12 or 9 Volts:
1-Leach mc (twice 9V)
2-Shek dac d2 (12V)
3-Record player Scheu (9V)
Now I was consdering battery powering these devices. But I was wondering If I use a car battery in combination with small isolation transformers and small stepdown transformers (custom made probably). I would then have a lot of amperes, only one battery to charge. The transformers would isolate the devices and stepdown the voltage to 9 Volts?
Will this work?
Old 27th September 2007, 08:02 PM   #2
Don S is offline Don S  United States
Transformers only work on AC, not DC. You could use resistors or regulators to reduce the voltage and isolate the devices. If you have the charger connected and operating while using the devices, you will see no benefit in noise reduction. You will probably have more noise than the dedicated power supplies for the units.
Thanks, DonS
Old 28th September 2007, 06:38 AM   #3
Thanks Don S, I forgot about the dc-ac thing...
Old 28th September 2007, 02:35 PM   #4
gni is offline gni  United States
gni's Avatar
Just use 3 pin voltage regulators. . . the output is isolated.
Is this a good idea? Nolantor19 Multi-Way 3 12th August 2009 12:36 AM
Is this a good idea? AC439 Multi-Way 0 30th December 2008 07:48 PM
Seems a good Diy idea !! sivan_and Everything Else 1 12th November 2006 07:44 AM
is this a good idea??? dmh Solid State 16 24th February 2005 03:47 AM
good battery for amplifier power supply? cowanrg Parts 0 20th September 2003 11:47 PM
Page generated in 0.07630 seconds (70.29% PHP - 29.71% MySQL) with 10 queries
