Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th February 2003, 02:07 AM   #1
Send a message via AIM to travis
Default what can/should i make with this?
i took it out of some little guitar amp. this can be baby's first high voltage project, or something.
donuts
Old 9th February 2003, 02:10 AM   #2
halojoy is offline halojoy  Sweden
On Hiatus
Can it be an output transformator?
You can build a Tube Amp, and use it as intended.
Or use it as filter choke in a power supply.
/halo - thinks a Tube Guy might recognize this thing
Old 9th February 2003, 02:11 AM   #3
it was a solid state guitar amp. odd.
donuts
Old 9th February 2003, 02:14 AM   #4
On Hiatus
Solis State Amp can sometimes use output transformators
as well. Especially old, and especially guitar.
It might been a tradition kept going.
/halo
Old 9th February 2003, 03:01 AM   #5
argo is offline argo  Estonia
IMO this is power transformer.
Read the text on paper wrap: XX2V 600mA (this is secondary winding); 110V 50Hz (this is primary winding)
Old 9th February 2003, 03:05 AM   #6
On Hiatus
Default yes, argo is right
Yes, you've got yourself a little Power Transformator.
0.6 Ampere
But how much volt?
Make a rectifier and connect a Cap between + and -
and see how much is the unloaded voltage DC.
/halo - hopes you have 110VAC and not 230VAC mains.
Old 9th February 2003, 04:03 AM   #7
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I think it could be 12V, but if it's much larger than that, it could be say, 112V, to feed a doubler for a tube amp. But since it isn't a tube amp, that goes phut out the window goodbye...
Tim
Old 9th February 2003, 04:17 AM   #8
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
You might use it for a door bell.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 9th February 2003, 04:28 AM   #9
On Hiatus
speaking of that.
Has anybody build any nice
DoorBell Amplifier recently?
It doesn't have to be high end,
but it does not hurt if the sound is good.
The guest would feel more welcome.
/halo - has only a 20 Watt Doorbell amplifier.
- gives enough volume for to notice the guests
Old 10th February 2003, 06:25 AM   #10
Banned
Send a message via MSN to SkinnyBoy
Make a 500watt doorbell amp, and mount speakers all over your door. . That way, the people will REALLY know they are alive.. lol
Make it worse to make it better??? moray james Planars & Exotics 23 12th May 2008 12:08 PM
What to make? Mayday Tubes / Valves 3 5th December 2006 04:20 AM
Make ac dc. Jasmeleg Parts 12 12th September 2005 07:14 PM
How make make a microchip, from a program? multiplexor Everything Else 1 20th February 2004 02:24 PM
Page generated in 0.09831 seconds (78.83% PHP - 21.17% MySQL) with 11 queries
