Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th September 2007, 09:29 AM   #1
Buzzy is offline Buzzy  Singapore
Default Need help on EQ circuit
Hi ! i would like to build the eight band sub eq from here http://sound.westhost.com/project84.htm
Right now i am sourcing for parts. May i know what type of resistors i should buy ? I am also confused on what capacitors C29, C38 and C39 are ? Can they be aluminium electrolytic ?
The power supply for this http://sound.westhost.com/project05.htm
recommends i use wall warts. However i would like to use a transformer. May i know how to connect the transformer to this circuit instead of the wall wart ?
Old 25th September 2007, 01:25 PM   #2
theAnonymous1's Avatar
Default Re: Need help on EQ circuit
1% metal film will be fine.
They are DC blocking/AC coupling capacitors. Aluminum electrolytic will work, but film type are preferred.
That all depends on the transformer. Does it have single or dual secondaries? If it has dual secondaries and the voltage is appropriate, I would use an external bridge rectifier and leave D1, D2, D4 and D6 out of the circuit.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 25th September 2007, 02:22 PM   #3
Thankz theAnonymous1. I have bought the resistors and the other parts. I found a transformer which is 15-0-15 10VA and a wall wart for about the same price. Which should i go for ? Btw i have trouble finding the LM7815 and LM7915. If i were to omit these will it explode ?
Old 25th September 2007, 02:52 PM   #4
The LM7815 and LM7915 are the voltage regulators. These are the heart of the circuit and building it would be pointless without them.
I WOULD say get the 15-0-15 transformer and a bridge recitifier, but if your not even familiar with what a voltage regulator is/does , then I suggest you stick to the original circuit and parts..
Circuit help jetbat Tubes / Valves 16 11th May 2009 04:23 AM
6c4 pre-amp circuit dito Tubes / Valves 2 2nd January 2007 07:42 PM
amp circuit help scott3292 Solid State 10 11th July 2005 11:16 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
What circuit? palesha Solid State 1 24th November 2002 10:18 PM
Page generated in 0.08435 seconds (72.35% PHP - 27.65% MySQL) with 10 queries
