Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Big Paper in Oil Caps
Old 21st September 2007, 12:02 PM   #1
chrish is offline chrish  Australia
chrish's Avatar
Default Big Paper in Oil Caps
Just saw these on EPay. Crazy big Russian 1KV paper in oil capacitors. Might be good for someone's project!
http://cgi.ebay.com/100uF-1000V-1KV-...QQcmdZViewItem
Old 21st September 2007, 12:25 PM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Only problem is shipping is more than they cost...
Old 21st September 2007, 01:21 PM   #3
chrish's Avatar
I live in Australia, so that is a fact of life for most things for us! Valve gear is heavy and costs plenty to ship. For the cheap Edcor transformers I have used, they cost as much to ship as to buy!
Chris
Old 21st September 2007, 04:44 PM   #4
zacster is offline zacster  United States
Bigger than the trannies. You need a chassis just to hold them. They look heavy too. I'll bet they sound better than electrolytics.
Old 22nd September 2007, 04:58 AM   #5
mach1 is offline mach1  Australia
Banned
Postage downunder can work out very cheap. Edcor use USPS flat rate boxes ($37) which can take up to 20lbs (lotsa small transformers). Either order a bunch yourself, or organise a bulk buy with other oz forum members.
Old 22nd September 2007, 05:48 PM   #6
dshortt9 is offline dshortt9  United States
dshortt9's Avatar
Solen makes 51 uf 1500V PP caps that are about 2" dia by 4 and1/2" long and may have suppliers everywhere. Other than that Motor run caps are available on e-bay most places and they are good for around twice the AC voltage. I have seen 80uf 500V AC on e-bay for 12 deflating american bucks.
Old 24th September 2007, 03:58 AM   #7
bassrogue is offline bassrogue  United States
bassrogue's Avatar
Send a message via Yahoo to bassrogue
I checked the shipping cost for a case of 4pcs... $45 to Washington state.
One question though, would these big caps. go bad after sitting a few years like smaller caps. do?
Just once I wish someone would call me "Sir" without adding, "you're making a scene"
Old 24th September 2007, 04:07 AM   #8
Magura is offline Magura  Denmark
Magura's Avatar
A piece of advice.....
Those caps must be more than 20 years old by now, so I would consider buying them to be risky business.
There are other options out there for both better and surely more reliable film caps, also bigger than 100 uF.
I have bought myself a handfull of PP in oil and a few PP in Nitrogen caps, ranging from 165uF to around 500uF as I recall. Those caps are though limited to 600V at full ripple. Reality is a lot closer to 1000V for audio use.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 24th September 2007, 05:51 AM   #9
felixx is offline felixx  Romania
felixx's Avatar
I use in some projects the same russians caps.
Also I have the same type of caps,only 68uf/400V but was made early 1965.
I put them on meter and I test those.
The real value is 67.89uf.
More than that I open some of these.They are really build and are garanted for life.The oil is still there and a lot.
Comparing with other polipropilene I prefer those.But should be tested first
"I'm glad I can build my own mistakes."
https://picasaweb.google.com/115586837612433686520
Old 24th September 2007, 06:43 AM   #10
sharpi31 is offline sharpi31  United Kingdom
I bought a case of 4 of these recently, and they arrived one week later in the UK. I paid $109 including shipping, which cost me 57.
I have tested all three with my LCR meter: two are 114.3uF and the others are about 116uF.
The crate was unopened and dated 1977. The caps are externally perfect.
I currently use 3x 20uF versions of the same caps in the crossovers of my speakers (open baffle fostex fe207e and eminence alpha 15a crossed over at about 275Hz). I have also tried large value polypropylenes but don't like these as much. Dynamically there is no comparison - just listen to any percussive music and the difference is clear.
I'm not sure what I'll use these new caps for yet.
Big Paper in Oil CapsHide this!Advertise here!
Repairing paper in oil caps. Shoog Parts 20 29th April 2009 02:19 PM
Paper-oil caps for sale nafanja Swap Meet 0 28th March 2008 06:43 PM
WTB/WTT PIO (Paper in Oil) Caps Andypairo Swap Meet 1 10th February 2006 07:19 PM
Paper in oil caps Jonathan Bright Parts 1 11th March 2005 10:51 AM
Paper in Oil caps - any good? Paulr Parts 4 20th August 2003 10:16 AM
Copyright ©1999-2017 diyAudio
