| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi warm folks!
Can we use a positive regulator to produce a negative voltage? I'm looking to build a +-15v (adjustable) using 1 or 2 rectifier bridge, and use 2 identical positive regulator (LM1086, LT1086, LT1963, etc.). I've found a schematics but they use 2 bridges. Can we use this with only one bridge, and remove the first stage of the schematics (darlington and opamp). Possible ? . |
#2 |
One bridge and center-tapped xformer: NO
Two bridges, isolated secondaries (and basic topology as shown): YES - Klaus |
#3 | |
I tried with only one bridge. It was funny. Boom. If I follow you, I can have for each: 15v secondary + bridge + caps + LM + caps And I connect the ground at output (or one ground plane for both ?) . |
#4 |
a dual positive supply can be series connected AT THE OUTPUT to give a dual polarity supply. But you cannot use a centre tapped nor a single bridge to create the two completely separate supplies needed for the commoned output dual polarity.
regards Andrew T. |
#5 |
If fact, if you already have the right transformer, the cost is only one bridge more and more work to design the pcb?
For the ground plane, on the PCB. Can we build it using all the component in red or we MUST build 2 separated ground planes et connect them at the exit (green). . |
#6 |
the sensing resistors feeding the regulator control circuits MUST SENSE the OUTPUT voltage, not some arbitrary point on a ground plane.
regards Andrew T. |
#7 | |
The objective is to produce someting better than LM317/LM337 couple with the minimum component and lower input voltage. . |
#8 |
Forgot the first PDF. I did a mistake. I not used the right pinout for the LT1965.
I've still some problems with grounding... . |
#9 |
Hi Stef,
you need to do more reading on basic circuits before you try to make them more complex. Fuses F1 & F2 might blow on first switch on. You can either make them bigger (less protection) or place them after the main smoothing caps. The upper bridge rectifier is back to front. The 10VA will give 410mAac maximum continuous current. After rectifying and smoothing the maximum continuous DC current is ~200mA. A 150mA transformer (3.6VA) will not do. If you want 15Vdc then you need a 15Vac transformer. 10VA will now give 165mA @15Vdc. The inductor before the first cap has not been designed to make this a choke regulated PSU. It will still act as a capacitor input PSU. the inductor in the lower 0v lead should be on the lower -ve lead. The sense resistors should be connected to the output. the ground in the lower reg should be connected to the negative supply line for this regulator (just like the upper reg is connected to it's negative supply line. Are these regulator stable with a low ESR cap on the output? where should C7 & C17 be connected? Sorry to appear so hard, but you would be better building a simple PSU first and understand what you have achieved, before you go regulated.
regards Andrew T. |
#10 | ||||
The fuses are not fuse but polyswitch. The LT1965 is a new low dropout regulator with low noise from Linear. It works with low esr caps. This is an example. We can replace it with others as the LT1086, LT1763 or others from National. The idea is to build something different of the regular 317/337 couple or the more detailed Sulzer type psu (too many component in my case, no space). Quote:
| Tends TA10 negative or positive grounded | emperor | Class D | 10 | 19th April 2007 12:39 PM |
| Small voltage deviation at positive and negative rail | 2Bak | Chip Amps | 1 | 14th December 2003 06:42 PM |
| why do we need negative voltage regulator ICs? | EJ | Solid State | 19 | 22nd August 2003 12:38 PM |
| Positive regulators for negative supplies? | JohnG | Solid State | 7 | 4th February 2003 12:28 PM |
| high voltage (>>37 V) negative regulator? | capslock | Solid State | 14 | 7th September 2002 11:41 PM |
| Page generated in 0.13948 seconds (76.24% PHP - 23.76% MySQL) with 11 queries |
