| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I've seen designs where the signal passes through the relay.
why not use ground on the relay contacts? something like this: http://img464.imageshack.us/my.php?i...itled1sv4.png. I saw a design by an Italian guy in the chipamp section. I'm just wondering that maybe using ground on the relay contacts is not applicable to every design? the left/right output wires are connected directly to the binding posts. thanks for the replies |
#2 |
Your link doesn't work.
Amplifier will probably go BANG. On deeper thought the speaker protection is really for after things go BANG anyway... With a fast blow fuse before the relay it should work. |
#3 |
the problem with doing it that way is that if your protection circuit malfunctions or false triggers, it takes the amp with it to amplifier heaven.
#4 | |
The forum software accidentally made the full stop part of the URL The following should work: http://img464.imageshack.us/my.php?i...titled1sv4.png |
#5 | |
It will make no audible difference. In a output stage feeding a speaker , the current left the output stage , pass trough the positive speaker wire , traverse the speaker and return to ground , by the negative return speaker wire. In a serial circuit like this , it makes no difference that the relay interrupts the sending or the receiving way, because the current in the circuit will always be the same... Regards
Jorge |
#6 | |
care to enlighten me? ===== thanks everyone for the reply |
#7 | |
when your protection circuit false triggers, it shorts the amplifier output to ground so that will certainly blow the output transistors. also, muting circuit like those often incorporate turn on mute and instant mute at turn off to eliminate pops, whistles or other weird noises when the supply voltage is not yet stable. if your amp has a loud thump at turn on (some amps do this normally) and the relay is closed, the thump goes to a direct short which (hopefully) blows the supply fuse (or worse) the expensive power transistors. |
#8 | |
thanks again |
#9 | |
However, an important difference between this scheme and the conventional arrangement is that the latter completely disconnects the amplifier output. With your proposal, the amp output is not disconnected from the output terminal, so it is still possible to short the amp to chassis, which is often connected to 0V. For this reason, I would not recommend using your idea.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#10 | |
Have you read the first post?
Jorge |
| loudspeaker protection relays? | h_a | Parts | 8 | 4th September 2008 07:43 AM |
| Relays to use in speaker selector | smithy666 | Solid State | 5 | 24th May 2008 05:45 AM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| Relays for speaker protection | wrl | Parts | 6 | 1st July 2005 05:35 AM |
| Relays for speaker protection | wrl | Multi-Way | 2 | 12th June 2005 06:26 PM |
| Page generated in 0.10940 seconds (86.14% PHP - 13.86% MySQL) with 10 queries |
