Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Comments, opinions on this equalizer.
Old 5th January 2008, 12:42 AM   #21
sam9 is offline sam9  United States
sam9's Avatar
I suspect the primary reason equalizers "sound bad" is that using them right/well is so bad. Even if you could avoid phase shift (which I think is the case when they operate on digital streams), It is very hard not to make the freq response worse rather than better.
I've fount the ones like Behriger's "auto EQ" do a better job than I can even when I come equipped with RTAs, SPL meters, test disc's etc.
Old 5th January 2008, 01:09 AM   #22
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Hi Sam,
I've seen these set in the "classic V", where the sliders slope up wards from flat in the middle to maximum at the ends. This would create so much distortion, it would be hard to measure.
I'm finding that the maximum boost before clipping on this unit is +2.5db and the maximum cut is about -4. Any adjustment outside of that narrow range causes massive distortion.
Anyway, I didn't expect much from this, just something to play with. At some point in the future I may convert it to parametric, with fewer bands and a limited range.
Old 5th January 2008, 01:46 AM   #23
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Originally posted by MJL21193
Part of the reason for this exercise is to prove to myself how much of a difference these "tweaks" make. You read a lot here about how different power supply caps sound this way or that way. I've always believed that to be nonsense.
You need to peel the plastic sleeve off the capacitor too.
Of course, a magic power cord will make all the difference.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 10th February 2012, 10:21 PM   #24
ZilogMan is offline ZilogMan  Canada
Sorry to resurrect a very old thread, I'm looking for a service manual or, at least, the schematic diagram for this Realistic EQ. Anyone?
Thanks!
ZM
Old 6th January 2013, 08:15 PM   #25
saul1960 is offline saul1960
me gustari saber si alguien tiene el diagrama de este ecualizador gracias
Comments, opinions on this equalizer.Hide this!Advertise here!
equalizer dr dingwhizzer Analog Line Level 9 29th April 2018 12:09 PM
ADC Equalizer GEirin Solid State 3 20th February 2008 02:22 PM
Need comments or opinions Madmike2 Multi-Way 6 8th July 2005 02:59 AM
DIY Equalizer, but really simple Christian Parts 9 20th June 2003 06:24 AM
