| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi there,
DON'T buy ST regulators, they are BAD. My devices are GENUINE, and my LM7915 gives-me -16,5v while my National give me -14,92v. I don't like much ST. Their power transistors are much more difficul to match than Fairchild for example, and I had a bad experience with their regulators today. I'm using their AMP, TDA7293V, and it performs VERY WELL despite the other bad experiences... Best Regards ! |
#2 | |
Enjoy good sound
No load during your test? At least 5mA is required in order for the regulator to function properly. -16.5V is way out of spec.
/ Anders |
#4 |
Also, I found you need !uF of output capacitance to avoid oscillation on the negative regulators whereas you only need 0.1uF with the positive ones.
#5 |
Electrons are yellow and more is better!
79xx and 78xx are quite different if you check the simplied schematics.
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
I didn't test it with a load, but it have a 100nF cap on it's output. Without load, the regulator from National gives a good voltage regulation, while the ST don't. I didn't test ST with load, as I tested it and after the reading I replaced immediatelly.
#7 |
BC550 from ON is not 100% compatible with BC550 from Fairchild. The same goes for these regulators.
#8 |
Oscillation???
#9 |
No oscilation
#10 | |
| Wolverine LT-12 in trash, looking for mate | Eratosthenes | Full Range | 6 | 11th August 2008 10:47 PM |
| Is there an improvement potential, or are these trash? | canakas | Multi-Way | 20 | 19th June 2007 05:21 PM |
| Should I trash these tubes | gingertube | Tubes / Valves | 7 | 27th May 2005 08:00 PM |
| 1B05 Trash it or use it? | mashaffer | Parts | 4 | 14th May 2005 08:09 AM |
| Page generated in 0.10066 seconds (75.83% PHP - 24.17% MySQL) with 10 queries |
