| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi Folks i need a simple aktive crossover like Harrissons F-Mod can anyone give me some info hove to do a active/Passive Crossover for the line signal without making it a complex filter i only want to cut everything under 90Hz in the line signal path and not on the speaker lines!,,, Cheerz Dag Zimmermann Stockholm sweden
PS: exuse my english im swedish you know:ds |
#2 |
Hej
If it has to be model-T and the filter doesn't need to be steep then you could simply use a smaller input cap on your power amp. If you don't want to fiddel with the amps internals then you may simply add one in series. To dimension this properly you'll need the circuit of the input section of the amp. Or at least a reliable input impedance spec. Regards Charles |
#3 | |
frugal-phile(tm)
You can eaily build your own. As Charles says a single cap (+ the existing input resitor on your amp) will give you a passive line level Hi-pass filter (1st order) Details can be found here. http://www.t-linespeakers.org/tech/f...ssiveHLxo.html dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 | |
a single pole filter will cut at 6db/octave (=20db/decade) below the turn over frequency. If you set the filter to 90Hz (F-3db), then the signal will be about 9db down at 45Hz and about 15db down at 22.5Hz. This is not even close to meeting Quote:
regards Andrew T. |
#5 | |
So I went for the simple solution. If it may be a little more complicated he might just specify how steep a slope he likes or how complicated it may be. Regards Charles |
#6 |
Tanx a lot folks will read up on the matter and try!...
| SIMPLE subwoofer crossover? | cowanrg | Subwoofers | 44 | 17th July 2011 04:57 AM |
| simple passive crossover? | CommanderZero | Parts | 4 | 11th September 2006 05:39 PM |
| Suggestion for simple crossover. | GuyPanico | Multi-Way | 2 | 5th August 2005 07:56 AM |
| Simple crossover tests | AntM | Multi-Way | 0 | 6th June 2005 03:24 PM |
| simple crossover | da_madaxeman | Multi-Way | 58 | 29th November 2003 01:58 PM |
| Page generated in 0.09333 seconds (74.90% PHP - 25.10% MySQL) with 10 queries |
