diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   RCA jacks for Yamaha M-60 (http://www.diyaudio.com/forums/parts/108144-rca-jacks-yamaha-m-60-a.html)
einthed 8th September 2007 05:45 AM
I'm in need of any information as to where I could find replacement RCA jacks for my Yamaha M-60 power amp. The outer cover for one of the Plugs has been lost. Both jacks are on one module and attached to a circuit board, so i need to find the whole unit. Maybe if some has a schematic for this or a similar model i.e. M-70, M-80 I could refine my search. thank you thank you
gni 28th September 2007 01:44 PM
M-60 input RCA Jacks
Couldn't add to thread of similar subject.
I would just wire in new RCA jacks. . . the input has a resistor and
cap. . . just wire them in correctly. . . series resistor and parallel cap.
Make it better than the original.
gni 28th September 2007 02:28 PM
Thank you moderator. . . .for adding the entry to this thread.
gni 28th September 2007 02:33 PM
Maybe we could swap. . . I have two M-45s that should have the
same input resistor and cap. . . I am in the process of swaping
them out.. . have replaced input resistor (carbon) with metal film
precision resistors. . .can post a picture if you like. I will have to
look at what the original resistor was. . . wrote it down somewhere!
gni 28th September 2007 11:02 PM
2 Attachment(s)
Schematic of Yamaha M-40/M-60 input.
Looks very similar to M-45
gni 29th September 2007 03:32 AM
I think the input resistor should be a 1.2kohm NOT 1.3kohm!
I replaced the 1.2kohm(carbon) with a 1kohm and 150ohm in one
amp and 1kohm and 220ohm in the other (1% metal films).
Copyright 1999-2017 diyAudio
