Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th September 2007, 11:46 PM   #1
MGH is offline MGH  United States
Default Top of the line Alps pot used in Kondo KSL-M7 preamp.
Anyone know how to get one of these?
Here a link with the pot in the Kondo preamp:
http://www.positive-feedback.com/Issue26/preamps.htm
Old 8th September 2007, 04:11 AM   #2
theAnonymous1's Avatar
IMHO you have to be an AudioPhool to pay $600 for a pot.... but nevertheless; your wish is my command.
http://cgi.ebay.com/ALPS-High-End-Hi...QQcmdZViewItem
I've bought a "poor mans" ALPS pot from that seller and the transaction went OK.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 8th September 2007, 04:51 AM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
They're a good seller and I bought a lowly motorised RK27 from them recently.... very smooth transaction.
Old 8th September 2007, 08:43 AM   #4
Thanks. Well it's either this pot or getting the Vishay S-102 resistor volume control from Placetteaudio.com, which is $1000. But I wonder if anyone has ever heard this carbon wiper control compared to the less costly Alps or stepped attenuators?
Old 8th September 2007, 09:28 AM   #5
QSerraTico_Tico's Avatar
A 47 position Shallco will cost you US$ 100 from Percy Audio and a few handfull of resistors plus a lot of time.
Used as a shunt pot you have only one resistor in series with the signal and one to ground for each setting, NOT a string!
Easy to calculate 1.5 dB steps and a wide range as many steps
http://www.siteswithstyle.com/VoltSe...ure_Shunt.html
Old 8th September 2007, 01:28 PM   #6
jarthel is offline jarthel  Australia
no need to use words like "fool"!
it his money and if he can afford it, why not?
Old 8th September 2007, 03:36 PM   #7
Who used the F word? I said Phool.
Old 10th September 2007, 05:05 AM   #8
Thanks all for your advice and info. All of us involved in the high end have been a "fool" or "phool" at least once. I may even buy this thing so I can compare it with other less costly options and answer the question once and for all.
Old 10th September 2007, 12:23 PM   #9
stoolpigeon's Avatar
If I added up the cost of all the cheap pots, switches, relays, resistors etc I've bought over the years its probably more than $600.
Looking for Alps switch (for Accuphase preamp) OliverD Parts 3 21st December 2009 07:28 PM
Audionote japan ( Kondo) Ongaku..Can I ......... Clone to DIY!!!!!!! tube-lover Tubes / Valves 84 20th June 2008 09:02 AM
Top of the line Alps pot used in Kondo KSL-M7 preamp. MGH Analog Line Level 2 12th September 2007 02:31 PM
OT: Tribute to Kondo-San sith Tubes / Valves 2 14th January 2006 08:15 PM
Page generated in 0.10521 seconds (75.40% PHP - 24.60% MySQL) with 10 queries
