Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th September 2007, 07:29 AM   #1
Electrons are yellow and more is better!
peranders's Avatar
Default Failure in a huge capacitor board
This is a rather tricky problem so I turn to people with deep theoretical and practical knowledge.
Any theories about this problem:
246 caps 1500 uF 35 V, Acrotronics type ESW http://www.arcotronics.com/download/aluminium.php?id=3
One of 500 caps "pops" at 28-32 volts only after they have been in soldering machine but even when we have taken caps directly from the package. One board hand soldered had a failure at 35 V after a couple of hours. All caps are tested with 300 mA/246 as charge current, very soft charging in other words.
We think that there is a production problem of the caps because the connections inside have sharp edges and the "booms" are always located at the sharp edges of the connector. The failure takes place after 1 min to several hours.
I wonder: Do we get a side effect of connecting so many caps in parallel? LC, oscillations, high voltages etc?
The short term solution is to changing to Panasonic. I'll guess the audiophiles will get happy about this
The cap board (plus 4 more boards with less caps) will take 1800 A in charging current. This has been tested for a month now with excellent results.
/Per-Anders (my first name) or P-A as my friends call me
Old 6th September 2007, 07:54 AM   #2
Geek's Avatar
Hi Peranders,
Have you used that company/brand for a while OK? If so, then I would say a manufacturing defect. Contact them. They'll appreciate the feedback to fix the issue and will likely credit your account.
If it's a new supplier, let me share with you my similar experience - don't cheap out on electrolytics run near capacity (excuse the pun).... the result is invariably *KABOOM!*
Good luck!
Old 6th September 2007, 07:59 AM   #3
What about heat dissipation problems with these narrow-spaced caps ? What if (possible) different path resistance exagerates this problem by uneven distribution of ripple current ?
Charles
Old 6th September 2007, 10:29 AM   #4
peranders's Avatar
Acrotronics 1000 uF/ 35 V have been used a couple of years and the numbers are 30000-40000 I should guess and they are 14 in parallel in the application but only 15 volts max but 250 A behind. There has been no failures in those products.
The problem here accurs at a couple of mA in charging current and always in steady state which is 8/246 mA (= quite small leakage).
What happens if a cap is connected to a power supply of 35 V with 1000 A and only a couple nH in inductance?
Can anyone see a possible reason why this is unsuitable?
At the moment (before we have tested Panasonic) I think this is to 90% a quality problem and to 10% a not a good idea to connect some many caps in this way.
Charles, the problem is at 25 deg C and at steady state, only leakage current.
We have a contact with the manufacturer but they have not yet got any samples from us (today maybe) but the answers so far tells us nothing really. One solution is to use 50 V caps but why does a 35 V pop at 28 V?
Old 6th September 2007, 01:15 PM   #5
"1 in 500 caps" That's 0.2%, which might be expected for a subtle cap defect, or might even be normal for a given type. Also check for seal problems and exposure to anything that would cause the cap to deteriorate if the seal were compromised. I've heard about LC issues on digital boards with many bypass caps, and think we even had that problem where I once worked, but you'll have to do some searching on that one.
Old 6th September 2007, 01:22 PM   #6
Elvee is offline Elvee  Belgium
Hi P-A,
I've had some experiences (nasty!) with large numbers of parallel-connected capacitors, both electrolytic and non electrolytic.
The problems are exacerbated by this parallel connection: when defects are cleared, in the case of self-healing for plastics and oxide cracks filling-up for electrolytics, there are normally small variations of voltage across the capacitor; when the capacitor is connected to a very "stiff" source of tension, this minute variation causes huge currents which stress further the (moderately) faulty capacitor, and precipitate a catastrophic failure.
This means that capacitors used in this way have to be screened with maniacal care to avoid problems.
A way to do that is to measure the noise on the charging current: even if the average leakage is very low, in the µA range, this current may be partly made up of relatively short and large spikes, which means the capacitor is unsuitable for // connection.
Manufacturers use a similar process to assess the quality of film capacitors. I remember C Bateman has written a paper around the subject.
LV
Old 6th September 2007, 01:24 PM   #7
peranders's Avatar
1 of 500 is not acceptable, not at rated voltage. We have 3000 caps in a cabinet so the probability to have 100% working is zero. I'll guess I'll have to wait until tomorrow or so to here what Acrotronics have to say.
Old 6th September 2007, 02:01 PM   #8
peranders's Avatar
Elvee, your conclusions seem not to be unlikely. Do you have possibly any more info. How did you solve the problem. My theory is that some caps are a bit weaker but not too weak in a normal application but my application is critical for this poor guy.
Old 6th September 2007, 02:30 PM   #9
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I'm curious though....
what application needs that much caps?
Old 6th September 2007, 03:00 PM   #10
peranders's Avatar
Can't say but a hint, where do you need 13000 A at low voltage? Input power is a switched PS of 21 kW, volume about 10 liters.
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 312 18th May 2012 01:32 AM
Cary 300SEI, likely capacitor failure zigzagflux Tubes / Valves 0 18th March 2009 05:58 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
Capacitor values on Aleph 5 main board. Tony D. Pass Labs 1 2nd October 2002 09:42 PM
Page generated in 0.12446 seconds (81.31% PHP - 18.69% MySQL) with 11 queries
