Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th January 2011, 01:12 AM   #71
unclejed613's Avatar
tantalum caps are notorious for dead short failures. NCR had a CPU board for a Proof Machine (a check processing machine) with about 10 SMT tantalum caps on it, and there were a lot of failures of those on the +5V rail. the epoxy case of the device used thermally sensitive color dyes in it so that the laser etching of the component markings would show up better. when one of the caps failed, half of the otherwise yellow epoxy case would turn brown making it easy to identify the failed device. regular aluminum electrolytics worked just fine as replacements
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board 7788q Class D 312 18th May 2012 01:32 AM
Cary 300SEI, likely capacitor failure zigzagflux Tubes / Valves 0 18th March 2009 05:58 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
Capacitor values on Aleph 5 main board. Tony D. Pass Labs 1 2nd October 2002 09:42 PM
Page generated in 0.06584 seconds (68.02% PHP - 31.98% MySQL) with 11 queries
