Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
digital or analog crossover?
Old 5th September 2007, 09:02 PM   #1
maghen is offline maghen  Sweden
Default digital or analog crossover?
I'm looking for advice regarding active crossovers for my line-array speaker project. (described in the "which loudspeaker design?" thread in "loudspeakers")
My current plan is to use a three way PA active crossover and tri-amp to bass, mid and treble respectively.
I know some people use the digital Behringer DCX2496 for HiFi applications. There are also already thought out tweaks to improve the fidelty.
On the other hand, I know some people successfully using analog active PA crossovers as well. (for instance the Behringer CX3400)
Choosing between these two units, which one would you believe is abetter choice? Pros and cons?
Thanks,
M
Old 6th September 2007, 04:23 AM   #2
Brett is offline Brett
Brett's Avatar
If I listened to digital only sources, a digital xover and multichannel analog volume control would be the choice. Add analog sources and I'd rather stay out of the digital domian.
Old 10th September 2007, 01:44 PM   #3
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
The DCX2496 makes a superb test bed for quickly finding out exactly what your crossover and driver equalisation needs to be. Then, once you've found out, you could build an analogue crossover.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th September 2007, 02:21 PM   #4
Brett's Avatar
I'm with you on that EC, it's a great test tool.
Old 10th September 2007, 02:26 PM   #5
ttan98 is offline ttan98  Australia
Default Re: digital or analog crossover?
Thanks,
M
I bought a second hand CX3400 it works very well and it is cheap. When you have more money then move over to DCX2496. You will not lose much money when you sell the CX3400.
I am planning to do this.
digital or analog crossover?Hide this!Advertise here!
Need help with a BSS Digital crossover and distortion on unbalanced analog Ken L Multi-Way 4 9th November 2006 01:14 PM
Digital or analog? xplod1236 Digital Source 1 19th May 2005 02:15 AM
Analog vs. Digital XO Seth Smith Multi-Way 11 1st June 2004 09:33 PM
digital or analog? electro samurai Digital Source 0 17th February 2004 04:07 PM
Analog to Digital? Ioannis Digital Source 5 11th December 2001 06:52 PM
