Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th September 2007, 05:22 AM   #1
oquela is offline oquela  United States
Default Wiring in an L-pad
I'm a bit confused. I'm making a 2 way, 12db crossover (Linkwitz-Riley) with a crossover point @ 2500 hertz (2.5k) I know that I must reverse the tweeter leads on this particular crossover to correct for phase.
My question is this: how (and where) do I wire in the L-pad I'm using to attenuate the horn? Is it before the High Pass filter, (where the wires are still out of phase) or after I've reversed the wires?
Old 5th September 2007, 05:28 AM   #2
frugal-phile(tm)
planet10's Avatar
After the XO and before the tweeter.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th September 2007, 05:36 AM   #3
Dave,
thanks for the quick response and attachment....so just to clarify, according to the drawing, the #1 lead on the L-Pad is what USED to be a tweeter negative, but is NOW the positive?
Old 5th September 2007, 05:42 AM   #4
frugal-phile(tm)
planet10's Avatar
yep
Wiring HT2 MTM ZoZat Multi-Way 4 15th May 2009 09:17 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Page generated in 0.08155 seconds (68.84% PHP - 31.16% MySQL) with 11 queries
