Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd September 2007, 06:06 PM   #1
crippledchicken's Avatar
Default bridge rect. upgrade question on PE BASH 500
i have some stealth diodes from Fairchild 15 amp 600v and 30 amp 600v. i haven't checked the original flat pack inline pin bridge on google yet for specs as i haven't removed the amp yet. i'd like some opinions as to whether or not this could maybe make an audible improvement. tighter bass,fuller, cleaner, more musical etc. or, due to the limited frequency range, not be worth the trouble? just wanted some more experienced opinions than my own. so maybe i won't waste alot of time for nothing. the amp is the Parts Express Bash 500 with switching ps. with caps rated at 200v 470 uf. not sure of original bridge rect. just yet! thanks for any opinions!
Old 3rd September 2007, 08:59 PM   #2
Default Re: bridge rect. upgrade question on PE BASH 500
built bridge with stealth diodes=much better!
Old 4th September 2007, 01:09 AM   #3
I have been using the Fairchild Stealth diodes to replace bridges in CD players, amps and pre-amps for years with good results.
MBR4060PT dual schottky rectifier as bridge rect. jscherer Parts 4 25th February 2009 04:21 AM
Pe Bash 500 Watt Amp Question crippledchicken Subwoofers 1 7th July 2007 02:14 PM
Int. Rect. Class D reference designs stoc005 Class D 3 17th February 2007 03:51 PM
ecc88 tube pover supply-rect. marijan Tubes / Valves 8 15th June 2005 09:50 AM
Possible damage of a 5AS4 full-wave rect... Layberinthius Tubes / Valves 2 1st February 2004 08:39 AM
Page generated in 1.10841 seconds (8.18% PHP - 91.82% MySQL) with 10 queries
