Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Lead soldering of leadfree parts
Old 1st September 2007, 03:17 PM   #1
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Question Lead soldering of leadfree parts
Is it OK to use lead solder to solder leadfree parts? Some of my inventory now is leadfree. I wonder whether I need to switch to leadfree solder - if I do will this solder the leaded parts good as well?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 1st September 2007, 03:58 PM   #2
leadfree ends solder well with leaded solder.
I do not recommend using leadfree solder. I have found the few types of lead free that I have tested are not nearly as good at wetting the surface nor for working at as low a temperature.
This seems to be the general finding of others.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st September 2007, 04:04 PM   #3
Did it Himself
Thanks Andrew. I know Lars Clausen had used some leadfree solder and said it was good, and worked just like leaded solder. But I have a reel of leaded that I might as well use.
Old 2nd September 2007, 01:25 AM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
I would echo Andrew's sentiment. The experience I have with circuit assemblies that were produced using Pb-free solder paste is that they are not as easy to rework because the Pb-free solder requires higher temperatures, does not wet as well, and does not always form a good solder joint. For DIY and personal stuff I only have 60/40 SnPb to use and it has always worked great.
Brian
Old 2nd September 2007, 06:30 AM   #5
Hi Bwrx,
if you think 60/40 is OK, then wait till you try 63/37 or even better 62/36/2Ag.
The disadvantage with both these is eroding of copper tips.
regards Andrew T.
Old 4th September 2007, 12:15 PM   #6
smithy666 is offline smithy666  Australia
Have you tried soldering large gauge cable that has been tinned with lead free solder?? You need to really wind up the temp (380 Deg+) to get a good connection, even when using lead based solder.
Lead free solder always leaves a dull finish, so it's difficult to tell whether you have a good solder joint, unless you trust your own abilities.
I agree with the others - stick to lead based solders if you can
Old 4th September 2007, 01:25 PM   #7
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
Hi Bwrx,
I have always used 60/40 and have a limited supply of 63/37 since I can't find any more of it here. but I really like using 63/37. never thought it erodes tips though.
Old 4th September 2007, 10:39 PM   #8
Bob, W7ETA is offline Bob, W7ETA  United States
http://science.nasa.gov/headlines/y2...htm?list618755
Still a novice with electronics.
Lead soldering of leadfree partsHide this!Advertise here!
RohS lead free soldering richwalters Everything Else 104 16th March 2008 02:33 AM
Lead free soldering! Pan Solid State 15 22nd November 2007 06:37 PM
Lead free soldering anyone? studiotech Equipment & Tools 2 24th August 2005 10:56 PM
silver/lead-free/copper soldering alloys metebalci Parts 1 5th May 2004 03:33 PM
Copyright ©1999-2017 diyAudio
