| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I was searching the mouser catalog and came across these: http://www.mouser.com/catalog/631/1201.pdf
can someone tell if these can be used in circuits that uses http://www.mouser.com/catalog/631/1249.pdf (Molex KK series headers/connectors)? Thank you |
#2 |
If pin spacing is the same, the can be used however note that the Tyco connectors are with a locking tab, intended to be held into place to the opposite part. The Molex headers doesn't have this so you risk that the connection is sensitive to small chock and vibration.
I know this because I'm sometimes using Tyco headers and Molex connectors (opposite yours), when I want to test something before foldering the wires to the headers.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
I apologize cause I wasn't clear.
I am thinking of using MTA headers/connectors or molex headers/connectors. I have used similar headers/connectors to Molex (used extensively in computer motherboard). But I am not use how the MTA looks/works. I looked at the datasheet and it seems wires are not crimped on the connectors? any suggestion which the best one to use? thank you for the help : |
#4 |
Both the Molex and the Tyco MTA's has the same way of attaching the wires (not saying that they you can use Molex og Tyco's and the other way round)
#5 |
thank you for the help.
I guess I'll stick with MTA. cheaper too |
#6 |
This might be slightly off-topic: Even though I am a big fan of mouser.com, I have found that, when buying Molex connectors, very often, http://www.alliedelec.com has a significantly-lower price, for them.
- Tom Gootee http://www.fullnet.com/~tomg/index.html |
#7 | |
that is probably true but if you're buying overseas, postage costs is not as cheap |
| Crown XTI2000 headers.. | fredos | Class D | 25 | 31st July 2009 10:08 PM |
| Female connectors for 0.1" headers? | theAnonymous1 | Parts | 2 | 25th March 2008 03:14 AM |
| WTB ultra low profile pin headers | JonHarrison | Parts | 1 | 21st May 2007 07:53 AM |
| 5 and 7 pin connectors | SRMcGee | Parts | 9 | 22nd September 2005 11:32 AM |
| pcb connectors, posts, and headers? | xdissent | Parts | 0 | 12th September 2003 11:53 PM |
| Page generated in 0.11192 seconds (82.84% PHP - 17.16% MySQL) with 10 queries |
