Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Help Identifying Diode
Old 12th September 2007, 06:05 AM   #11
OzMikeH is offline OzMikeH  Australia
Diodes used like that are to exploit the volt drop across them, it is to provide a low impedance way to get a 0.7V drop for the bias of the power transistors. The PN junction in the transistors is also about 0.7V
The good news: any old standard diode should work provided the current rating is suitable. (no schottkys/high speed, just a dumb ol diode)
The bad news: usually the diode is killed by a shorted transistor.
while you have the diode tester out look for a shorted Base-emitter or base-collector on one or more transistors.
When powering up for testing use safety resistors, (see elliot sound products webpage for tips)
Help some guys with funny hair bang two rocks together really hard.
Old 12th September 2007, 06:28 AM   #12
ashwick is offline ashwick  India
Thanks again
Help Identifying DiodeHide this!Advertise here!
Help Identifying Cap..... dmongrain Parts 13 1st June 2009 03:20 AM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Help in identifying ST OP AMP packer Parts 3 8th July 2007 09:21 PM
Identifying a cap... EchoWars Parts 4 27th August 2006 10:43 PM
