| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
what are they really made of?
some models of the same manufacturer specify silver cadmium oxide, others are listed as silver/nickel (90/10) and etc. I want to use the relay for speaker protection so I'm looking at which are suitable. thank you. |
#2 |
I'd say that it likely doesn't matter.
But, many amplifier designers have pondered the same questions, and ended up using relays such as the Omron LY2 and MY4. If you have room, use one relay for each channel, and run all the contacts of each relay in parallel for current carrying capability. |
#3 |
relays do not like breaking high DC currents. Supplement the output relay with close rated supply line fuses. If you can, add an input mute that cuts the normal AC signal at the output relay before it opens.
regards Andrew T. |
#4 |
to andrew: how is the fuse connected?
======== to echowars: why 1 relay per channel? ==== thank you for the help |
#5 |
the supply fuses could be at the PSU if there is no provision on the amp PCB. Or even in line fuses could be used.
regards Andrew T. |
#6 | |
| what is the best metal/alloy for DIY wire resistors ? | mikelm | Everything Else | 6 | 8th November 2004 06:26 AM |
| cleaning of relay contacts or replacement | Keith D | Parts | 12 | 31st July 2003 07:32 AM |
| Mercury wetted relay contacts | stadams | Everything Else | 5 | 7th June 2002 03:56 PM |
| Page generated in 0.09738 seconds (76.41% PHP - 23.59% MySQL) with 10 queries |
