| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm building a reclocking circuit for my dac. I need help choosing a board with appropriate diameter througholes for the parts: 14-dip and 16-dip flip flops a tent clock and tent shunt reg with a handful of caps and a few screw terminals for wiring to and from board. This will be all point to point including gnd bus wire.
The ideal dimension would be approx 2" x 7" with througholes that accept the above parts. Thanks, Mike |
#2 |
Mike,
Before you decide anything, search for info on a Flea PCB, here and on Google. Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner? |
#3 |
Thanks for the suggestion. As far as I am able to understand, the flea pcb is a circuit not a blank board. I am implementing a reclocking circuit that is specific to my dac and source.
This is my first board level project and need some help spec/sourcing a blank perforated board. epoxy? with througholes of a diam and spacing that will work with 74hc74 flops, tent clock and standard resistor leads, etc. Thanks for any suggestions.
Cheers ~ Mike |
#4 | |
I haven't found a good source for these though, DigiKey is grossly overpriced and none of my local B&M's have a good stock. I usually source my protoboards from random eBay sellers, but YMMV with this. I believe RadioShack carries a few different protoboard layouts that may suit your needs. |
#5 |
Thank you! I was just on the 74HC74 flop datasheet to check on the spacing and pin diameters. The digikey boards are expensive! Their hole diam is 0.042" which appears large enough for these flops, standard size resistor and cap leads, etc.
Looks like 0.042" diam will just allow an 18awg wire to be threaded through. So this looks like it will work with 0.1" standard spacing I'll check out radioshack. thanks again!
Cheers ~ Mike |
#6 |
Try these (reasonable):
http://www.futurlec.com/ProtoBoards.shtml http://www.kelvin.com/ele_proto.html Hope this helps! Good Luck! Regards//Keith
| T-AMP Board T type Audio Amplifier | hllyelec | Vendor's Bazaar | 20 | 12th February 2009 02:55 AM |
| Reclocking to tda1541 pc board | weegs | Digital Line Level | 0 | 12th May 2008 11:45 PM |
| help with reclocking circuit | pho_boi | Digital Source | 33 | 24th November 2006 06:34 PM |
| reclocking circuit | ackcheng | Digital Source | 12 | 4th March 2005 04:51 PM |
| Lost 1 Zv4 ckt board..looking to buy 1 circuit board | Blues | Pass Labs | 1 | 22nd March 2004 10:09 PM |
| Page generated in 0.09003 seconds (74.96% PHP - 25.04% MySQL) with 10 queries |
