Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th August 2007, 01:03 AM   #1
seilee1 is offline seilee1  United States
Default Shielding/Foil Tape
I'm working on some switches for a MIDI mallet percussion instrument (just using a cheap controller's brain and hooking up each key switch in the matrix to a homemade switch with no velocity sensitivity). For these switches, I'm planning on having three layers: a conductive strip on the bottom of the vibraphone-style key, another similar conductive strip below this, and then a thin open rectangle in the middle which separates the two strips but lets them touch when the key is struck. Anyway, for the keys' material, I'm using a roll of that thin rubber/plastic strip that they use for those rubber baseboards. I wanted to see: 1) if shielding tape is conductive on the non-adhesive side, 2) if the tape will adhere to rubber alright, and 3) if anyone had recommendations of good tape for this application (the cheaper the better).
Shielding ..... sakis Solid State 9 20th July 2009 07:34 AM
Shielding with aluminum foil;) murat Solid State 20 29th December 2004 10:16 PM
RFI/EMI Shielding, is it necessary? mkruger Parts 1 22nd April 2004 05:54 AM
3M Conductive Copper Foil EMI/RFI tape KevinLee Swap Meet 0 25th May 2003 03:11 PM
Page generated in 0.09299 seconds (67.42% PHP - 32.58% MySQL) with 10 queries
