Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th August 2007, 08:38 PM   #1
neil_kaye's Avatar
Default Wiring PLitron 30VA, 2x30VAC
I need some help wiring my plitron 30VA transformer. The input needs to be 115AC and the output for dual secondaries at 30VAC (2X30VAC).
The way in interpret the plitron diagram is that for the primaries for 115VA I wire the black to ground and orange to live. The white gets wired to the orange and the brown to the black.
For the output i wire the red and yellow to one board, and the blue and grey to the other board.
http://www.plitron.com/shopping/specs/0170XX201.pdf
Please confirm if this is correct?
Old 24th August 2007, 11:03 PM   #2
Chartal is offline Chartal  Canada
For the primary you have to wired them in parallel.
Black is the Line (hot) and white is neutral.
Connect black (1) & brown (3) to the Line
Connect white (2) & orange (4) to Neutral
Don't forget to use a fuse before the connection 1 & 3 of your transformer, 1 amp slow-blow should be ok.
For the secondary your wiring is OK.
Old 25th August 2007, 01:20 AM   #3
neil_kaye's Avatar
thanks, just fired it up and works great
Plitron transformer wiring? woody Power Supplies 0 27th March 2008 01:10 PM
Wiring PLitron 30VA, 2x30VAC neil_kaye Power Supplies 1 27th August 2007 01:45 AM
Talema 30VA wiring question... chipco3434 Power Supplies 1 14th December 2006 01:39 AM
Plitron 30VA, 6-0-6V transformer orthoefer Swap Meet 0 4th September 2006 09:34 PM
Page generated in 0.07723 seconds (68.70% PHP - 31.30% MySQL) with 10 queries
