| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
l would like to custom-made a toroidal power transformer because my old transformer broken. This power transformer is multi secondary output and center tapped winding (sec 1=0-9vac and sec 2= 71vac-0-71vac). Primary voltage is 230v with power rating @ 30va. The transformer dimension is 70mmx25mm. I'm not sure how to calculate the current ratings? If I want to change the power rating to 50va, what should be the current? Can someone help. Thanks. Rgrds/Roy3932 |
#2 |
Without knowing how much current each of the existing secondaries had to deliver, you can't know how the VA rating was shared by the multiple windings, only that increasing your VA rating will increase the proportional capacity of each of the windings in a higher rated xfmr.
There may be some merit in picking apart the bad xfmr and measuring the diameter of the the magnet wire (not the external leads) for each secondary. From this we could estimate typical design current density used in xfmrs. (worst case 250-300 circular mils/A, conservatively perhaps 1000 CM/A). Regardless of what current density the designer assumed, we could estimate the load ratio between the two secondaries and work backward to determine currents. It would be an educated guess, perhaps better than having no info. Is there any way for you to estimate what each of the the windings has to accomplish? I wish I knew why it take 2-3 attempts for me to post. I'm always told I'm not logged in the first try. Murray
Murray |
| Power Supply Rating / Fuse calculation / Understanding ? | artquake | Power Supplies | 23 | 24th June 2008 10:41 AM |
| power transformer rating and tube current - SimpleSE | cbutterworth | Tubes / Valves | 17 | 12th June 2008 11:54 PM |
| Current rating and tube current draw | cbutterworth | Tubes / Valves | 1 | 13th October 2006 05:42 AM |
| How to test transformer's current rating? | kmtang | Tubes / Valves | 6 | 12th September 2006 07:44 AM |
| Transformer VA Rating vs. Current Rating | JhonDoe | Chip Amps | 45 | 5th June 2004 02:11 AM |
| Page generated in 0.07536 seconds (70.13% PHP - 29.87% MySQL) with 10 queries |
