Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st August 2007, 08:33 PM   #1
jackinnj's Avatar
Default Noise and your Handheld DMM
There was a recent Nuts n Volts article "Build the JCAN" -- a device to measure resistor noise -- hmmmm, I wondered whether you can measure noise out to 100kHz or so with a high quality hand-held DVM.
The Fluke 8920 and HP 3403 use a thermopile, the Boonton and Tektronix AA501 use the AD536 Log-AntiLog converter. I used a Genrad 1381 random noise generator with 2kHz, 5kHz and 50kHz bandwidth. The answer is:
Old 21st August 2007, 09:03 PM   #2
jackinnj's Avatar
The little bit of variability amongst the true, true RMS meters relates more to the bandpass filters in the GR1381 -- this is, after all, a circa 1968 noise generator.
Low noise transistor and noise figure Real_Macgyver Solid State 26 31st January 2011 01:34 PM
FS: BK Precision 3001 Handheld audio signal generator davidhs Swap Meet 3 6th May 2007 06:18 AM
Red LED noise. GK Solid State 5 14th December 2006 03:12 AM
Page generated in 0.07382 seconds (70.07% PHP - 29.93% MySQL) with 10 queries
