Just a quick one here... I remember that there is a method one can use to use two polarized caps in such a way that they behave as a single non-polar cap. Apparently this was used in some loudspeakers to make a "large", inexpensive non-polar cap.
What a cannot remember is the the method itself. It involved wiring the caps with either the positives together or the neagatives as below:
Can anyone help jog my memory?
Code:
or
Think of it this way:
Two series caps in a crcuit actually form a loop consisting of the two caps, some generating source voltage and a load (impedance).
It doesn't take much reference to Tevanin and Ohms to understand that in such a loop the components (4 of them!) can be connected in any order to achieve the same effect.
THUS, the two caps can be + to + or - to - and the circuit will not know the difference.
No magic.
No magic.
True. But in this case, I am "borrowing" a design I've seen in some Infinity speakers to get better LF extension from a less-than-optimal enclosure (Cetec/Gauss 2841 driver in a 60l sealed enclosure). I had to find a way to get a roughly 2200uFd/60V bi-polar. In this instance, I had two 4700uFd/71V electrolytics to get a single 2350uFd cap.
In any event, it worked out splendidly.
There's also an old technique where you put the two caps in series, and connect a diode across each one, I believe the diodes are wired so that the cathodes go to the + sides of the caps. The idea is that on each half of the cycle a diode shorts out 1 cap, giving you a bipolar cap that's the same value as one of the series caps instead of half that value.
I've never tried it, so I'm not sure how well it works, I would think there'd be some non-linearity at low signal levels though.
- Design & Build
- Parts
- Polarized to non-polar capacitor wiring
