Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th August 2007, 03:09 AM   #1
Bob0513 is offline Bob0513  United States
Default Ground Trafo case
Hello all,
I am using an E-I type transformer for an amp and it is enclosed in a metal case. Should I connect the case to ground or just leave it unconnected? The case I am using is wooden, so it is obviously not grounded.
Thanks,
Robert S.
Old 19th August 2007, 01:12 PM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
Yes you may, some EI cores Ibuy localy, even have a ground spade for easy connecton.
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 01:08 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 3 28th February 2003 05:31 PM
Page generated in 0.06992 seconds (65.08% PHP - 34.92% MySQL) with 10 queries
