| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Has anyone tried the following acrylic film surface mount caps?
http://www.cornell-dubilier.com/catalogs/FCA.pdf I found these at Newark, although Digikey has what looks like the same or very similar cap made by Panasonic: http://www.panasonic.com/industrial/...8_ecpu_dne.pdf You can get up to 1uF @ 16V in a 1210 package, and cost is reasonable. The datasheet claims "good" audio performance, so at least they were thinking about it. Thanks for any info, John |
#2 |
I guess not...
#3 |
With a dissipation factor of 1.5%, I would guess these are slightly worse than polyester capacitors, which usually have DF specs like 1%.
[Polypropylene DF spec is usually about 0.1%] |
| Film capacitors for decoupling | rotation | Tubes / Valves | 4 | 6th November 2007 09:02 PM |
| SCR film capacitors?? | kimschips | Parts | 2 | 19th June 2005 02:25 PM |
| Black Gate FILM capacitors, anyone? | slawney | Parts | 0 | 10th September 2004 11:43 AM |
| what are the film capacitors? | Wagener | Solid State | 2 | 5th May 2004 11:23 PM |
| what film capacitors do you use? | arnoldc | Tubes / Valves | 31 | 7th February 2004 04:01 AM |
| Page generated in 0.06403 seconds (77.57% PHP - 22.43% MySQL) with 10 queries |
