Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th August 2007, 02:27 PM   #1
Default Question about component tolerance and probability
More of a probability question than electronics, but it can be applied to many electronic components:
Let's say we have two 100 ohm resistors, 5% tolerance each. If we put them in parallel, the equivalent resistance is 50 ohms, but what is the equivalent tolerance? How can we compute this?
Just to make things more difficult, a follow-up question:
Say we have a 50 ohm resistor, 5% tolerance, and a 200 ohm resistor, 1% tolerance. Their equivalent parallel resistance is 40 ohms, but what is the equivalent tolerance?
Old 16th August 2007, 02:50 PM   #2
Did it Himself
richie00boy's Avatar
Purely theoretically, it's 1/((1/5) + (1/5)) with equal weighting to the resistance, like in your first case.
However this takes the assumption that tolerance spread is distributed evenly and thus some cancellation occurs. I personally would not use it as a way to get closer tolerance, I would just use 1% parts from the start.
Your second case I'm not sure but maybe the tolerance of the higher resistor is weighted in proportion to your lower one, e.g. it contributes a 1/4 of the overall value. Multiply the tolerance of this part by 4 using the above equation.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 16th August 2007, 03:09 PM   #3
PigletsDad's Avatar
In reality, if you use two 100 Ohm resistors from the same production batch, you will typically find they have very similar values, so the tolerance is not altered.
Old 16th August 2007, 03:25 PM   #4
Warp Engineer
On Holiday
AudioFreak's Avatar
Worst case would be that one of the resistors is 5% high and the other resistor is 5% low giving a worst case tolerance of 10%. As you add more and more in parallel, statistics would generally dictate a normal distribution which should have enough of the resistors close to the nominal value that the tolerance of the whole network is seen to improve. In practice, you'd be relatively unlucky to pick two 5% resistors from the same batch that are at either end of the allowable tolerance.
- Dan
Old 16th August 2007, 03:30 PM   #5
Did it Himself
No that's wrong, your example would have a tolerance of 0% - think about it...
Old 16th August 2007, 03:59 PM   #6
Geoff is offline Geoff  United Kingdom
Sorry, you are both wrong. If you parallel a 105R and a 95R resistor (ie 100R +/-5%) the end result is 49R875 which is 50R -0.25%
Paralleling two equal resistors results in a halving of both the value and the tolerance, so two 100R 5% resistors become 50R +/-2.5%.
Old 16th August 2007, 04:16 PM   #7
Default Re: Question about component tolerance and probability
The 'worst case' situation (both resistors maximally high or low) results in a deviation from 40R of 3.23%.
Old 16th August 2007, 05:14 PM   #8
Boris_The_Blade's Avatar
not true...
paralleling two 100R resistors with 5% tolerance, that say are 105R each will give 52R5. which is 50R +/- 5%, tolerance stays the same...
Old 16th August 2007, 05:51 PM   #9
Originally posted by Boris_The_Blade
not true...
I stand corrected. You are absolutely right. I must have been having a senior moment when I edited my post to add the second paragraph.
However, this means that richie00boy's equation in Post #2 is also incorrect.
Pre-amp component question billnchristy Solid State 13 15th August 2008 10:24 AM
Crescendo ME (component) question.. Dxvideo Solid State 16 29th November 2007 06:36 PM
probability of success with ucd180+diy power supply mazurek Class D 3 9th November 2005 06:04 AM
quick bias tolerance question...across source resistors Mattyo5 Solid State 6 12th October 2003 11:09 AM
Page generated in 0.10015 seconds (80.79% PHP - 19.21% MySQL) with 10 queries
