| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Dilletante, tinkerer and beggathoner supreme
try these links
http://www.allansmusic.com.au/Product.aspx?p=53281 http://www.allansmusic.com.au/Product.aspx?p=53890 Still reasonably cheap Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#12 |
The unit I borrowed had minor (but significant) level discrepancies when both channels were set to the same level by the dial markings: 2-3db differences in some positions. Additionally, the crossover frequencies between the two channels were as much as 25% different when the dials were set to the same position.
This isn't necessarily easy to hear in a multichannel system until you fix the issue. These crossovers are great for what they are, but if I were leaving one in my system long term or evaluating other system components or changes, the problems need attention. |
#13 |
Hi Jeff, must say that that isn't audible to my aging ears, differences in X-over freqency that i had noticed I was attributing to the power that I was using with each band.
But that said; perhaps there have been different manufacturing batches with somewwhat of a quality control issue
#14 |
I agree it's tough to hear what's wrong - until it's corrected! I set each channel's dial set to the same position as best as I could at what I thought would be 500Hz. When I measured one channel was actually crossed at 700Hz and the other was crossed at nearly 900Hz! I measured the unit alone with a laptop soundcard - no amps in line to mess things up.
If you have the patience to measure when you want to change something, this isn't a problem. The unit performs fine when properly configured by measurement. I agree that my sample may have been out of spec, but the tolerances of typical cheap pots aren't fantastic so this could be typical. |
#15 |
I decided it's not for me. I downloaded the manual, the delay adjust is for the low channel only. I want time adjustment in the highs as well. I'm doubtful the adjustment is fine enough for 10kHz wavelengths, it's 41 steps from zero to 2ms.
I'll measure my speakers then build a line level 24dB/oct XO to suit, Delay circuit (if required) can be incorporated in the XO box at the same time. I may even stick a T amp in there for the tweeters. |
#16 |
Jeff, Do you still have your movie theater speakers?
-Manny |
#17 |
I have the CX3400 and it's horribly noisy. I have to keep the input gain knobs down a lot and send it a higher level signal to compensate to get an acceptable SNR. It's not my receiver or amp.
thinking of replacing some op amps. Don't feel like taking it apart until I know what I'm doing. Anyone do this, or at least got pics of its guts? |
| dBX 223XL vs Behringer CX3400 active XO? | grantnsw | Multi-Way | 29 | 25th June 2012 08:00 PM |
| Inside photo Behringer CX 2310/CX3400 | potepuh | Parts | 3 | 21st October 2010 08:41 AM |
| Behringer cx3400 crossover | keyser | Everything Else | 7 | 15th July 2005 06:41 PM |
| FS : Behringer CX3400 Active 3way crossover | Jean | Swap Meet | 4 | 12th July 2003 10:28 PM |
| Modifying Crossover Advice | BigMacX | Multi-Way | 2 | 6th August 2002 08:49 AM |
