| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I looking for a fancy wooden enclosure to house a small electronics project. It needs to be about 8 inches by 6 inches with a sloped (console) top so that the front is shorter than the back.
This unit here http://www.crookwood.com/products/Mo...s%20-%20C2.htm is similar albeit slight more complex to what i am building. It is basically a monitor controller. I have not had much luck finding a console enclosure that doesn't look so generic like the ones in radio spares so any directions here would be great. Thanks |
#2 |
Plywood and a bit of glue should get you going... If you want you can draw the whole thing out and maybe ask a local DIY shop to cut the planks out for you... A few coats of hamertone from a can, gets pretty hard over time, and has that antique electronics looks.. it is also pretty easy to fill the gaps and cracks by just applying a few extra coats of hamertone there... it is very forgiving in hideing blemishes...
Or even just the plywood and some danish oil. |
#3 |
Thanks.
There must be some nice well crafted cases somewhere. Any ideas? |
#4 |
This is DIY after all
I've just recently finished a DAC enclosure out of MDF and pine (with a view to painting it - hence I don't care about the wood used) but it could have easilly been done with some nice plywood. I was hoping to post a photo at some point, but I wanted to sand and paint it first. |
#5 |
I have found some nice units from Hammond if anyone is interested
http://www.hammondmfg.com cheers Jon |
#6 |
Have you tried www.boxcleverltd.com they have a vast range of enclosures, or they can vacuum form or plastic fabricate to your ideas.
| Custom Wooden Audio Enclosures | zeroed4x | Vendor's Bazaar | 0 | 24th June 2009 10:50 PM |
| What to do with these 4 consoles? Please Help! | ncalsurfer | Solid State | 8 | 27th August 2007 05:48 AM |
| Wooden Enclosures Prt 2 | pjpoes | Solid State | 17 | 28th March 2005 02:45 PM |
| Page generated in 0.08821 seconds (71.87% PHP - 28.13% MySQL) with 10 queries |
