| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#31 |
Seems like several of you had good projects going. What results did you get with the new National preamps, and can you share circuit ideas?>>
You got me going now. I have built the circuit on page 12 of the LT1115 datasheet. Can I improve on this circuit using the National preamps referred to e.g. the LME49710 which is described as "near to perfect"... Andy Evans |
#32 |
IME a cheap FET input opamp will beat these pricey National chips because it loads the cartridge much less, which is a big deal with my Grado.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#33 |
I should say that I use a Audio Tehnica OC7 moving coil cartridge, so in my case I'm optimising for MC.
I guess the Grado is MM? |
#34 | |
#35 |
I just rebuilt a Bluenote brand phono box for someone.
It sounded so good..that the owner of that unit gave me his Chord balanced phono pre, in return. it is full of OPA27 opamps. OPA627? Sounds about right.....
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#36 | |
A slightly rude sounding question: Are you using at least polystyrene bypass caps, right at the pins, on the OPA627? It makes a quite notable difference. I'm thinking my current work will need something like this Johnson noise analyzer. (I thought Johnson noise was something that happened when.....nevermind) Do folks feel this is a workable device? Edit: Ok. will investigate the national chips.
#37 |
Hi all
I am using a modified Rotel RQ970 as HiFi World mods from the 90's. The design used AD743, now unobtainable in the UK i have tried both AD 797 and LT1028, with reasonable results. I am using a DL160, hi output MC, shoud I consider this to be a MM or MC from the standpoint of Op Amp selection? THanks |
#38 |
i'd also recommend at least trying the AD743 as a front end for a mm riaa preamp.
maybe can buy direct from AD? i thought they were still making this part ... i just got some OPA827 and OPA211 which I've heard good things about. i would consider the OPA827 for the front end of a mm riaa preamp. personally, i also like the opa627, but they are expensive and probably too old for some people's taste ... :-) mlloyd1 |
| Favorite low power chip amps | johnr66 | Chip Amps | 12 | 17th December 2010 11:29 AM |
| Your favorite diy and commercials amps and cases ? | gaetan8888 | Everything Else | 0 | 1st July 2009 01:15 AM |
| My favorite preamp | 7n7is | Tubes / Valves | 13 | 30th March 2008 03:51 PM |
| MC Riaa preamp help/opinions please | duderduderini | Tubes / Valves | 15 | 6th March 2007 03:42 PM |
| RIAA Preamp | Justcallmedad | Solid State | 4 | 2nd September 2005 02:52 AM |
| Page generated in 0.10103 seconds (72.46% PHP - 27.54% MySQL) with 10 queries |
