| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi all! I'm looking to build this amplifier and am looking to see if it's possible (or advisable) to remove electrolytic caps from the power supply. Or maybe it's best to do a hybrid. For example, I was thinking of using one Mundorf M-Lytic HV 200+200uF 500 VDC after the diode bridge and then one 47uF PP from here after the IRF device. What do you think?
Here's a link to the project Also, I'd be interested in recommendations for the 0.1uF, 1000V bias capacitors... I was condidering the SCR Teflon Tin Foil Cap that are available on Ebay here This is my first time working with such large working voltages for caps, so I'm not really sure what to do here... Thanks! |
#2 |
where are all the part geeks?
#3 |
I do beleive that electrolytics are necessary. These seem to work best with biased voltages. I once met a person tha t did take them out and lost bass on his amps and could not figure out why.
Hear the real thing! |
#4 |
hm ... is there such thing as a bipolar tube rectified supply that could do -+ 400 V DC? I'm looking for a way to soup up the power supply
#5 | |
#6 |
luvdunhill, your ears will thank you ridding your power supply of electrolytics. Among passive components, electrolytic capacitors are the worst offenders. Actually, I hesitate to call capacitors "passive," but j'digress: electrolytics are junk offenders that diminish the finer elements of music reproduction.
I've not heard the Solen teflons, but suspect they're quite good. Teflon is at the top of the heap for capacitor dielectrics, and gives a pleasing, upgraded sound in most implementations. Also quite good are Russian teflons of the K72P variety. I've seen 1000V versions on eBay. These capacitors have steel leads which are better removed to reveal an inner silver wire that can be drawn out of the capacitor to form the new lead.
Tom |
#7 | |
#8 |
More capacitance than less is probably better before the C30. Start with 200uF if affordable to you. After the C30, I would think 47uF to be adequate, perhaps even too much, possibly slowing the sound somewhat; I would shoot for the best quality capacitance you can obtain for that position, including teflon bypasses. You can begin with even smaller capacitance in both positions, then use your ear to determine if adding more improves the sound.
Tom |
#9 | |
#10 |
I have the cheapest Conrad Johnson pre-amp. There are no Electrolytics anywhere. They must have a reason.
regards Andrew T. |
| Jensen 4-pole too $$$ - Power Supply Can Capacitors Recommendations | mrdon | Parts | 1 | 23rd February 2007 11:46 PM |
| metallized caps instead of electrolytics in a tube rectifier power supply? | jarthel | Tubes / Valves | 15 | 26th May 2006 05:46 PM |
| Removing excess voltage from amplifier supply? | Dazzzla | Solid State | 21 | 20th April 2004 01:43 PM |
| T-Network Power Electrolytics | mrfeedback | Everything Else | 1 | 13th July 2002 03:33 AM |
| Removing switchmode power supply noise | ih | Digital Source | 1 | 25th April 2002 09:18 PM |
| Page generated in 0.12429 seconds (79.45% PHP - 20.55% MySQL) with 10 queries |
