Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd August 2007, 11:25 PM   #1
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default Too much gain
Hello,
With the help of richie00boy, I made project 71, (the Linkwitz Transform, from Rod Elliotts site), a reality. I'm taking the Loudspeakers output of my amp via a headphone circuit to drop the output to drive the input mixer and so on. Illness has taken my mind away from things, and although not better, I'm getting on with things.
Anyway, I'm using a car amp in bridge mode to power the woofer, and I have the gain turned down on the amp and yet the volume level is too high. With the LT set at 20hz, and not wanting to change things, I tried changing the resistors in the headphone circuit, but still the signal is too strong, I tried a 240k volume pot off an old amp, and it released some smoke ! It was wired as a potential divider. Whats going on, can you help? Would I have some DC getting through? If so, how can I check without a Scope
Mike
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Gain Blockwith Variable Loop Gain Bonsai Solid State 17 11th July 2008 03:40 PM
How much gain should I have? komen Chip Amps 2 26th March 2006 02:32 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 02:30 PM
Unity Gain Operation (or low gain) Tomo Chip Amps 12 22nd January 2004 02:47 AM
Q on amp gain Andrey Solid State 1 18th June 2002 10:48 PM
Page generated in 0.07552 seconds (67.84% PHP - 32.16% MySQL) with 10 queries
