Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
DN2540
DN2540
Old 3rd November 2011, 07:17 PM   #41
On Hiatus
SY's Avatar
DN2540
Don't know that circuit. Does the DN have a gate stopper resistor? Nice and close to the gate lead?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 3rd November 2011, 08:23 PM   #42
tmblack is offline tmblack  United Kingdom
Yes the DN has a 330 ohm gate stopper resistor but I breadboaded it on a solderless board.
So I have 4 versions of CS:
1 two DN2540 cascode
2 one DN2540
3 one 2SK170
4 one 2sk170 inside a DN2540 cascode
the pure DN2540 versions 1 and 2 allow hum to pass through.
I'm using a cheap wall power transformer power supply.
Old 3rd November 2011, 09:16 PM   #43
TheGimp is online now TheGimp  United States
TheGimp's Avatar
How much voltage do you have across the current source?
Old 4th November 2011, 05:09 AM   #44
Poindexter is offline Poindexter  United States
Depends on what you mean by 'better'. Rdyn is about 20-30% higher. Otherwise, it's a matter of availability. There were times when the IXYS part was unobtanium, but the DN2540 has always been scarce. I would use whichever was available; I don't think there will be any difference in normal (not approaching design limits) service.
Poinz
Old 4th November 2011, 09:15 PM   #45
I recon the DN2540 has less than 2V Vds in the inner cascode, total of 8V across the cascode.
Old 5th November 2011, 04:45 AM   #46
Alain Poitras is offline Alain Poitras  Canada
Alain Poitras's Avatar
2 one DN2540
3 one 2SK170
Don't forget the 2SK170 come in three IDSS ranges (Vgs = 0V) :
2SK170GR : 2,6 to 6,5 ma
2SK170BL : 6 to 12 ma
2SK170V : 10 to 20 ma
The 2SK170 is very good as current source and source follower buffer but personally, I will never use them as commun source amplifier ...
Alain.
Old 6th November 2011, 04:24 AM   #47
TheGimp's Avatar
tmblack,
You may need more voltage across the current source to get good cmrr out of it.
Old 6th November 2011, 10:47 PM   #48
Alain.
I'm just testing the 2SK170 because that was what Nelson Pass has in his JFET BOZ.
I plan on using the current source devices on a tube preamp next, modding the 12ax7a or 7247 in the EICO ST70.
Old 6th November 2011, 10:49 PM   #49
Originally Posted by TheGimp View Post
tmblack,
The DN2540 has been used on cathode end of power tubes. What is a typical voltage to get good CMRR?
Old 7th November 2011, 04:00 AM   #50
Are they good as current sources in the range of 0.5mA to 2mA?
Some say a gate resistor should be used, or can I just ground the gate to the source resistor?
No problem using the DN2540 for 0.5mA to 2mA and a 2K resistor between the gate and the source is safe.
The DN2540 is very good for high voltage use in tubes circuits, VDS up to 400V but a minimum VDS over 10V is the best. A good alternative to replace the DC load resistor or choke in plate circuits to make some kind of SRPP circuit.
The 2SK170 is a low voltage device, a maximum VDS of 40V but you better use it in a range from 2 to 20V, then no good for plate circuit but OK for cathode circuit like in a "long tail pair" phase splitter.
You just have to take care not exceeding the maximun power dissipation, you may need a heatsink in many cases, sometime a very big one for the TO220 DN2540 version with a high current ...
For both 2SK170 or DN2540, you should use a multiturns trimpot to adjust the bias because there can be a big current difference between different specimens and datasheets curves, IDSS and Yfs (Forward transfer admittance). Also keep in mind JFET current drop with temperature raise ...
Alain.
DN2540Hide this!Advertise here!
Help on Cascode DN2540 CCS swordsman Tubes / Valves 1 24th December 2008 04:48 AM
dn2540 chip jarthel Parts 1 1st October 2006 01:51 PM
do I need to use a heatsink on a DN2540 in a B+ supply? jarthel Tubes / Valves 1 28th September 2006 06:42 AM
DN2540 N TO-220 Available dshortt9 Parts 0 15th September 2005 04:12 PM
Wtb Dn2540 woody Swap Meet 1 22nd July 2005 03:44 PM
