Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Resistors Watt rating : how to check it ?
Old 31st July 2007, 06:43 AM   #1
rephil is offline rephil  Europe
Default Resistors Watt rating : how to check it ?
Hi all,
In using a resistor we all are faced with its Watt rating. We normally use it with some safety margin as if 1 Watt is dissipated in it, the used resistor will be rated at much more in order to get a trustworthy circuit.
The problem I have now is related to the Watt rating of resistors that are sold on the net.
I have bought for cheap many 1% resistors that should be rated at ½ Watt as was told in the eBay auction. As I don’t see any difference with those that are rated at ¼ Watt already in my boxes at home (they look all the same way), I should like to know if there is a possibility to check that a resistor is rated at ¼ Watt or at ½ Watt. How do they proceed to check this rating in the industry ?
Please, consider that I am not allowed to ‘appreciate’ explosions, flames, fumes and the like in my lab as my family would not let me proceed with such a ‘dangerous’ hobby ... . So the check must be non destructive . .
Thank you for any help.
Best regards
rephil
Resistors Watt rating : how to check it ?Hide this!Advertise here!
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
2.7R zobel Resistor...Watt Rating? Wynand Chip Amps 12 7th October 2007 05:39 PM
Resistors -- using higher-than-required watt rating slowpogo Parts 5 12th January 2007 08:28 PM
Sub Watt rating? Frisbee78 Subwoofers 5 5th February 2004 11:37 AM
Copyright ©1999-2017 diyAudio
