Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th July 2007, 06:17 AM   #1
Send a message via MSN to -_nando-_
Wink Simple Eagle question. I already searched, but I didn't find what I want.
Hi !!
Look at the attached image. I have this whole circuit, and I need to select ALL and COPY it, as the "second" part of the schematic is the same as the first.
I tried to select Group, and then copy, but it don't work. What is funny is that, it works to move it, but I can't copy paste it.
Another thing is, is there anyway to "import" an schematic, or use part of other schematic project in a new one?
Like, if I have two projects in eagle, one named Distortion, and another named Heavy Distortion. The first is a simple distortion and the second is the same as the first, but with one more distortion stage, so I would like to open the schematic of the "Distortion" and use it's contents to create the "Heavy Distortion", to avoid drawing it all again. Is it possible?
Sorry about asking these simple questions, but I seached a lot and I didn't find anything like this.
Thank you very much.
Best Regards!
Old 29th July 2007, 06:49 AM   #2
ashok's Avatar
Your second question.
Open the file 'distortion' make all the changes you need and then save it using "save as" and enter a new file name . The original will remain as before and the new one will have another file name.
For the first question . I haven't solved that yet !
Cheers.
AM
Old 29th July 2007, 07:56 AM   #3
Yes, I already know this method, work for this situation. But when you're doing a project (glue work) that involves lot of small projects, it doesn't work
Eagle is a great design tool, but there's some basic things missing so much...
Old 29th July 2007, 09:26 AM   #4
joho is offline joho  Netherlands
Talking copy function Eagle
Dear Nando,
Once i had the same problem.
Please use the "cut and paste" function!
Make a group first, as you did. Use cut,left click in the middle of the group and use paste.
You probably expect that the "cut group" disappeard but it doesn't.
Good luck
Johan.
Old 29th July 2007, 10:45 AM   #5
Nordic is offline Nordic  South Africa
Nordic's Avatar
Thanks for the cut and paste... been bugging me for ages... just tried it now, and it works schweet.
Old 29th July 2007, 11:19 AM   #6
Default "cut and paste"
Eagle is a great program but most people(included myself)are to lazy to read the help-files. But after a few hours of trial and error without any result it's the last chance.
When you think about "cut and paste" a ordinairy windows user expect different results and that's the problem.
Gr.
Johan
Old 29th July 2007, 08:46 PM   #7
Wow, it's obvious, how could I not see it !?
And as I can perceive, many people here had the same problem LOL
Thank you so much !!!!
Searched, but can't find tube enclosure company The Paulinator Multi-Way 1 7th February 2006 05:37 PM
another DUMB question (i've searched the site) Nanook Chip Amps 1 10th March 2004 09:21 PM
Page generated in 0.09829 seconds (74.76% PHP - 25.24% MySQL) with 11 queries
