| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#2 |
Here are just a few things my friend google found.....
http://sharon.esrac.ele.tue.nl/mirro...oise-Pulse.htm http://www.national.com/nationaledge/jun04/article.html http://www.jbgizmo.com/page19.html http://octopus.freeyellow.com/sine.html http://www.aldinc.com/pdf/osc_42004.0.pdf http://www.interq.or.jp/japan/se-inoue/e_ckt18.htm http://www.redcircuits.com/Page13.htm http://www.electronics-lab.com/proje...rs_timers/016/ http://www.ryanmcginty.com/orgone/freqgentutorial.htm
"If you don't like funerals don't kick sand in ninja's face." |
#4 |
The very first one has a sweep function, but it's a complicated project.
If you only need a set sweep range, the absolutely easiest way I can think of would be to load a sound file of the sweep onto a cheap portable device like an mp3 player. Is using a PC an option?
#5 |
Maxim has a chip that does it. Look for Function Generator, I forgot the exact type number.
Edit: MAX038 Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#6 |
aah sorry! Started with the second link.
Hm, PC and expensive circuitry is not an option. I wanted to build a cheap, simple interval circuit for synchronus motors. Maybe a good way to get in touch with microcontrollers. But that would take to much time. Call it a sunday afternoon project. regards |
#7 |
There are modern and better ways, but I'd just go to my junk bin and pull out an old 8038 or one of the Exar chips.
#9 |
How nice does the sinusoid have to look like ?
There are methods to generate sinusoidal approximations using shift registers and resistors. The shift register can be clocked by the VCO part of a 4046 CMOS PLL IC. Regards Charles |
#10 |
starting from zero it might take a little more than a afternoon but you could probably progam this that quickly if you are familiar with uC dev environments:
http://focus.ti.com/docs/toolsw/fold...430-f2013.html complete developement kit only US$20, spare uC boards US$10 example code "Using PWM Timer_B as a DAC": http://focus.ti.com/lit/an/slaa116/slaa116.pdf also cheap mp3 player could be dedicated to the task, easier if battery power ok, could add power thru usb port for cont operation, some older 256K/512K flash devices can be found for <US$30 |
| Sinewave Inverter Design | Karakacha | Power Supplies | 20 | 13th September 2010 04:27 PM |
| Smoothing modified sinewave Inverter | simontay1984 | Power Supplies | 10 | 27th December 2009 06:07 AM |
| Use of a Ribidum Oscillator as refrence oscillator in a DAC | Mark A. Gulbrandsen | Digital Line Level | 18 | 2nd January 2009 10:57 PM |
| modified sinewave inverter operation | Mark25 | Everything Else | 1 | 14th April 2003 04:21 PM |
| Page generated in 0.09541 seconds (83.96% PHP - 16.04% MySQL) with 10 queries |
