| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi Everyone
This is my first post, I'm a newb here. I have been collecting and restoring tube radios for about 12 years. The last few months I've become very interested in tube audio. A friend built me a single ended tube amp and I built a preamp. Both turned out excellent. I have now started on a phono amp. My question is about the bridge that I bought for my filament supply. I have 6.3 VAC from my transformer. I hooked up the bridge and have 16.6 VDC with no load or no filter cap. I'm puzzled, this can't be right, right?? Seems to be acting as a doubler. Thanks in advance. Great forum. David |
#2 |
You probably need a different lesson. Not all AC meters are the same. Most assume a sine wave input. A rectified signal clearly is not a sine wave.
Put your capacitor filter in there and a slight load and things may behave and be closer to 8 volts if I remember my PS design math. One other thing to watch out for is that selenium rectifiers need to be simulated if you are duplicating earlier designs using this technology. They have a very high series resistance and thus a high voltage drop. |
| GBU805 Bridge Question | westers151 | Parts | 0 | 18th March 2009 02:42 PM |
| wiring two transformers to two dual rectifer units | larryg | Chip Amps | 13 | 14th February 2009 05:09 PM |
| GTO 2000 (JBL) bridge question | mikee55 | Car Audio | 15 | 13th August 2007 02:45 PM |
| Grounded Bridge Question | rtarbell | Solid State | 3 | 22nd June 2006 08:05 PM |
| Bridge Rectifier question | hotscot | Power Supplies | 14 | 15th January 2006 05:15 PM |
| Page generated in 0.06306 seconds (70.29% PHP - 29.71% MySQL) with 10 queries |
