Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th July 2007, 02:42 AM   #1
takeda is offline takeda  Greece
Default Input Analog Multiplexer [Please Help]
Hello everybody,
First of all i have search the forum and didn't find a solution.
What i want is an input multiplexer for my diy amp.
The input stage before the power amp is
where the buffer is used to match impedance for pga2310.
I have tried ADG409 (http://www.analog.com/UploadedFiles/...ADG408_409.pdf) without success. (Just hooked it up no extra parts, resistors filters or anything except the decoupling capacitors)
The problem was HUGE crosstalk plus noise when changing channels. Also some spikes could be heard from the speakers from time to time.
I also have MPC507 (diffential analog multiplexer) but I haven't tried out that yet.
Please give me any recommendations, circuitry corrections, how to hook the multiplexer or anything to help me out.
In case needed, my amp lookes very well grounded, analog star for analog grounds and bus connection to digital ground (with a low pass filter).
PS. One of the multiplexer inputs will be a DIY dac , another one a digital radio module and the others, typical unbalanced analog RCA source like in consumer dvd players.
Available analog bipolar power supply voltage is +15,-15
no sig
Old 25th July 2007, 02:34 AM   #2
What should I write a title to get some views and some help?
hot chicks + free pizza and beer?
no sig
Old 25th July 2007, 03:16 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Dont have to.
Have u try the Dallas/Maxim website???They do produce some good multiplexers.
Old 25th July 2007, 12:26 PM   #4
i'check it out, thank you!
no sig
Old 25th July 2007, 12:41 PM   #5
multiplexer and complaining about crosstalk.
What are you expecting the first section to do? Give us a brief.
A multiplexer usually on digital signals (but also on analogue) can mix together differing inputs such that a de-multiplxer can separate out the original signals without any loss.
Is this what you really require?
regards Andrew T.
Old 25th July 2007, 12:59 PM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally posted by AndrewT
mutliplexer and complaining about crosstalk.
Andrew,
I think he wants source selection.
Jan Didden
Old 26th July 2007, 03:10 AM   #7
Yes, source selection.
Sorry for the missunderstanding..
no sig
Old 26th July 2007, 04:28 AM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hi takeda,
Would you consider using signal relays to do your switching? They will sound much better with lower crosstalk. Terminate each source with a 100K resistor and also the "out" side with another 100K resistor. This will help the crosstalk some.
Then you only need to switch the coils using 12 V relays and a resistor. I would suggest a separate rectifier and supply for this. Also a separate ground return path. Let the entire thing float if you can. Optocouplers would work here.
Normally an IC input selector gives the sound a bit of a "grainy" character in my experience.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 26th July 2007, 09:40 AM   #9
or just a 4pole 3way rotary switch.
regards Andrew T.
Old 26th July 2007, 09:18 PM   #10
anatech's Avatar
Hi Andrew,
LOL!
I almost posted that, but after looking at his circuit I though he may have wanted remote control.
-Chris
Digitally controlled analog Input/Output stereo audio processor tolaemon Chip Amps 3 17th January 2011 10:08 AM
Asus Xonar Essence STX analog input? fotios Digital Line Level 1 25th April 2009 11:55 PM
Need Replacement for TC9152 Analog Audio input Selector IC tdownes111 Analog Line Level 3 18th August 2007 07:20 AM
Best sounding analog switch IC for input source selector rythmikaudio Solid State 10 28th February 2007 03:26 PM
CMOS multiplexer as input source switch Leolabs Parts 1 17th October 2006 11:10 AM
Page generated in 0.10823 seconds (80.00% PHP - 20.00% MySQL) with 10 queries
