| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can anyone help me identify a component? It seems to be a positive adjustable voltage regulator, TO-3P package, capable of at least 100v input. There are absolutely no identifying numbers or logo's on mine, though a friend with the same amp has a small logo on his regulator that looks like it might be S something (SGS?) Input is on the centre terminal. (So it is NOT a TL783). The guy who built the amp is overseas and out of reach. Please help me ..... I am missing my music!!!!!!!!!!
#2 |
A picture of the board? Could it be a transistor?
#3 |
Thanks for the suggestion. You could be right. I will try to post a pic 2 morrow. If it is a transistor, it seems highly unlikely to be faulty as the B+ is only 90v.
As for a pic, I don't know whether anyone will be able to make out much from it as this is a hybrid design and the power wired and signal path comes and goes from the board making it a bit difficult to work out what's going on without the whole amp in front of you. The problem is a distortion that seems about equal in both channels, which is why I suspected a power supply problem. It is not severe, but is noticeable. I have since laid hands upon another amp the same and found the voltage readings I took from it pretty similar, so now I am even more in the dark. I did replace the output mosfets and found the distortion slightly worse, so perhaps it is to do with setting the bias point of the fets (which I have no idea how to do). |
#4 |
Hi AnalogSA. Sorry no pics. I figured that if anything was going to be damaged, it was not likely to be a power transistor, so assuming you were right, I replaced a TO92 transistor (MPSA42) and an electrolytic cap (100v 100Uf) and the problem was solved. Actually, the amp was better than ever, probably because I used higher value parts. The MPSA 42 was replaced with MPSA43 and the cap was replaced with 200v 220Uf (taken from a switching supply). The turn on thump that I have lived with from the beginning is also gone now. I have since added an extra bypass to the cap (.22uF polyprop) with good results. I may try a 1000uF cap soon, since I have one and it is the same size as the 220uF. It may give me a bit of an overblown sound, but the only way i can find out is to try.
Thanks for your help. |
| Mystery RF amp | spooney | Car Audio | 11 | 25th April 2008 07:14 PM |
| little 6.5 mystery ... | oface | Full Range | 6 | 5th November 2007 12:20 AM |
| mystery regulator? | hihopes | Solid State | 0 | 22nd July 2007 10:39 PM |
| Mystery SE OPT | alexmoose | Tubes / Valves | 4 | 11th July 2006 02:29 AM |
| mystery... | mista2 | Multi-Way | 1 | 14th January 2005 05:20 AM |
| Page generated in 0.08261 seconds (74.30% PHP - 25.70% MySQL) with 10 queries |
