Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th July 2007, 08:17 PM   #1
redrabbit's Avatar
Default Inverting opamp input resistors calculation (pic)
This device has an internal 2k feedback resistor.
The pdf scan is poor, and I am confused about the INput resistor that goes to ground.
It looks to be either :
Rl (load)
or
Rf (fdbk resistor)
.....but Rf is already the internal 2k, right ?
Perhaps I don't understand the part of the equation:
"For Zin = 50 ohm, select Rg || Rf , =50 ohm" ...what does that mean ?
whole datasheet:
http://pdf1.alldatasheet.com/datashe.../CLC200AI.html
=RR=
Old 18th July 2007, 03:11 AM   #2
radtech is offline radtech  United States
I'm going to say it's Ri for input.
The equation means if you want the input impedance to be 50 ohms (very common in RF work) you should select Rg and Ri (not Rf) to equal 50 ohms when connected in parallel (for instance both 100 ohms).
Rg by the way, controls the gain.
Old 18th July 2007, 08:38 AM   #3
Calvin is offline Calvin  Germany
Calvin's Avatar
the CLC200 is an old Device intended for RF use. For Audio its parameters are far from optimal.
So whats the application You are going to use it for and what gain do You need?
Radtech´is right. The resistor connecting from Vin to Gnd is Ri
The || signs mean ´parallel to´. So Zin calculates to:
Zin= Ri*Rg/(Ri+Rg) Keep in mind, that 50Ohms may be too low as load for the signal source to drive it properly, or changes the calculated values when used as buffer in filter circuits, etc etc.
Rf is the internal feedback resistor value, connected from Pin8 to Pin5.
2k is an already low value, which leads to even smaller Rg values, hence small Zin values (even with the low gains typical for Audio)!
Raising Rf´s value by using an external resistor You´d probabely have to compensate with a little cap connected to Pin4. If You have measurement possibilities You could do that, otherwise..hands off!
Summed up, I wouldn´t recommend or use the CLC200 for typical lowgain audio stages. There are lots of cheap and modern devices around that do a better job in that application area.
jauu
Calvin
Old 18th July 2007, 09:12 AM   #4
had a quick scan thro' the datasheet, is this a current feedback opamp?
4000V/us is fast, but is it suitable?
regards Andrew T.
opamp inverting input sounds better? dorkus Solid State 89 24th November 2011 11:53 AM
Inverting opamp cct ...blocking cap? - help! HankMcSpank Solid State 1 28th March 2009 10:24 AM
Class D input LM311 Inverting input zox2003 Class D 1 1st February 2008 07:48 AM
Input impedance of a non-inverting op amp? glennb Chip Amps 24 21st May 2004 03:24 AM
Input impedence of inverting gainclone PHilgeman Chip Amps 1 7th January 2004 03:33 PM
Page generated in 0.08905 seconds (75.65% PHP - 24.35% MySQL) with 10 queries
