| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Unlike the screw type which is easier, how do you mount this capacitor properly? Appreciate any ideas, links or suggestion. regards, Roland
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo... |
#2 |
The mountings are included in your pic.
regards Andrew T. |
#3 |
Screw them to the bottom of the chassis... ?
#4 | |
Looks like Sponge Bob has killed another thread. |
#5 |
Might be a good idea to discharge them before option 2...
#6 | |
Will it result in capumans or humacitors? |
#7 |
A manual override if they're charged, i think
(minus the m and the u)
#8 |
roland,
you can line them up on sheet of paper to locate holes, i assume you will use all 8 of them right? so that piece of paper can serve as your drilling template.... now for the proper orientation of the lugs, you can loosen the side screw a bit and orient the cans till you get all positive or negative terminals lined up, then tighten them back... this is how i do it, could work for you... hey, this is diy, jsut ask and you shall recieve......
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#9 |
Actually I am not sure he meant "mount"... he probably meant "connect" hence the screw type reference he makes...
Roland just solder them with 8 gauge wire (if too hard, use 10 ga). |
#10 |
I think he is asking how do you properly mount leads to the top of the caps.
Looks like they are designed to accept crimp terminals like this- (fully insulated quick disconnect) ![]() or this (uninsulated quick disconnect) ![]() or solder wires into the little holes.
My DIY audio projects- PartTimeProjects.com. |
| Mounting snap-in caps | 454Casull | Power Supplies | 5 | 20th December 2010 09:05 PM |
| Horizontal mounting of large capacitors | bitnissen | Parts | 2 | 26th April 2008 01:21 PM |
| Paralleling small value caps with large value PS caps | xyrium | Power Supplies | 16 | 14th October 2005 04:06 PM |
| Proper mounting of TO-247 Devices | Mark A. Gulbrandsen | Pass Labs | 18 | 20th December 2002 02:49 AM |
| Heatsink mounting large devices | trwh | Parts | 6 | 13th September 2002 05:09 AM |
| Page generated in 0.10562 seconds (75.02% PHP - 24.98% MySQL) with 11 queries |
