I am designing my theater room (studding it our right now) which will be in the basement. 125watts/channel Sony, Velodyne sub, 5.1 surround and 100-inch front projection tv.
The room is 15'W x 25'L, 7-foot ceiling and concrete floor.
Where would be the best place to locate a "room shaker" and how powerful should it be?
I've been checking out Aura's Bass Shaker Pro (50 watts/channel) - should I look for something a little more powerful? And where could I possibly put it when all I have is a concrete floor?
Thanks!
Thanks!
Hard to beat the Butt Kicker.
http://www.thebuttkicker.com/
Goes down to 5 Hz, from 400 to 1600 W.
I doubt very much if any bass shaker is going to do anything bolted to a concrete floor. You want to be on a suspended wooden floor for best results. Bolted to the sofa should also work.
Phil
Phil
haldor said:Hard to beat the Butt Kicker.
Butt what?
You should check out the "technical" document on that site.
http://www.thebuttkicker.com/downloads/BK2_UserGuide.pdf
It has some info regarding the best places to mount a shaker.
From what I've heard, typical shakers don't need much power. Somewhere in the order of 30w. Anybody have any experience with these?
