Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th August 2007, 10:12 AM   #21
ashwick is offline ashwick  India
This is a general question with regard to very inexpensive electret mics
freely available . There is generally a FET inside the capsule itself for impedance conversion purposes.The question is: What is the quality of these FETs? Can we take them out and use them for for low noise audio applications(like front end of tape head amps etc?)
Members may please adivice
Old 9th September 2007, 08:09 PM   #22
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Originally posted by ashwick
This is a general question with regard to very inexpensive electret microphones. There is generally a FET inside the capsule itself for impedance conversion purposes. The question is: What is the quality of these FETs?
Because I need to make a microphone amplifier, I thought I'd try measuring the FET in a few capsules. The gate is effectively connected to the source internally, so Vgs = 0 and that's the only curve we can have. Here's a very cheap 3/8" capsule from Maplin. Note that the FET will be reasonably linear once Vds > 1V, but that Ids is only about 300uA. There's not going to be much gm in that FET, so we can expect plenty of noise...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 9th September 2007, 08:13 PM   #23
EC8010's Avatar
Here's a Panasonic WM60 1/4" capsule. The vertical scale is now 2mA (rather than 500uA) and with Ids four times greater at 1.3mA, we can expect twice the gm and commensurately lower noise. More interestingly, we need at least 5V across the capsule before we get proper performance out of the FET - no wonder the "recommended" circuit with only a volt or two performed so poorly! (The coggle at 2.52V is probably a measurement artefact.)
Old 14th May 2011, 10:22 PM   #24
I'm working on a project to use 2 mce-4000 electret capsules inside a guitar body. I'm proposing to track core and sleeve signal cables to inputs on two preamp circuits ( see Simple Microphone Preamplifier ) . I want to get inouts from 2 different zones of the guitar , The outputs from the twin pre-amps will go into the line level inputs on my mixing desk. The mic inputs on the desk have 48v phantom power which I assume would toast the capsules hence the twin pre-amp approach.
Electret Microphone Capsules cm961 Parts 12 6th February 2012 11:24 AM
Matching transistors for electret microphone? cafh Everything Else 3 12th April 2007 12:16 PM
Balanced electret microphone circuit scone Multi-Way 3 1st February 2005 09:16 AM
Page generated in 0.07575 seconds (75.39% PHP - 24.61% MySQL) with 11 queries
