| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
I'm just about to design a microphone pre-amplifier for exactly the same use as you. I'll be using an electret capsule where I assume that the source of the FET in the capsule is either already disconnected from the case, or can be disconnected from the case. Op-amps will not be involved. Yes, I will post the design if it works properly.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#12 |
#13 |
I'm also in the process of fiddling with an electret microphone.
I am trying to repair a shotgun mic that had a broken electret capsule. The microphone body itself doesn't seem to have another amplifier so the only amplifier in the whole unit is the FET built into the electret capsule. I replaced the capsule and biased it using the circuit on the bottom of the page zobsky pointed out. I changed the 1K resistor to 2.2K because my electret capsule said its impedance was 2.2K. Everything seems to work but the output of the mic is very low. Not sure if an external amp was orignally needed because this mic seems to plug direclty into the xlr jack of my camcorder. THanks |
#15 |
What exactly do you mean by without the extra circuitry?
Like directly hooking up the electret capsule (with the battery and biasing circuit) to the xlr jack? I believe the microphone itself has some other circuitry inside, but i think its for the M and V switch which toggles a rolloff filter or something. |
#17 |
Oh, the mcirophone body itself has an AA battery, and I'm pretty sure it's used to power the electret capsule. So there has always been a battery involved in powering the capsule; before and after the repair.
#19 |
Well, sort of.
The original capsule was a 3 pin one. I replaced it with the circuit i mentioned earlier: a 2 pin capsule, the resistor, and a capacitor. |
| Electret Microphone Capsules | cm961 | Parts | 12 | 6th February 2012 11:24 AM |
| Matching transistors for electret microphone? | cafh | Everything Else | 3 | 12th April 2007 12:16 PM |
| Balanced electret microphone circuit | scone | Multi-Way | 3 | 1st February 2005 09:16 AM |
| Page generated in 0.09452 seconds (80.17% PHP - 19.83% MySQL) with 11 queries |
