Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109?
Old 16th July 2007, 03:12 PM   #1
jarthel is offline jarthel  Australia
Default 2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109?
I've seen a reply where someone said it's okay to replace a 2SK107 with 2SK389 (same for 2x 2SJ74 in place of 2SJ109) but I want to confirm.
Also why is there a need to glue them? I saw this photo: http://www.diyaudio.com/forums/attac...amp=1171282640
The transistors are facing each other. But since I want to replace a 2SK389 with 2SK170, I cannot have them facing together unless I bend the pins to make it work?
thank you for the help
Old 16th July 2007, 03:17 PM   #2
luvdunhill is online now luvdunhill  United States
luvdunhill's Avatar
yes, it's okay to use the single versions.
The devices are glued together for thermal coupling, which improves the degree to which the can be matched (not the best choice of words, but you get my drift).
I'd recommend about 15 of each single version to find 1 closely matched pair, as in my experience these can vary widely even with the same grade.
Old 16th July 2007, 03:36 PM   #3
I already have matched pairs. does this mean I do not need to glue them?
thanks again
Old 17th July 2007, 08:19 AM   #4
h_a is offline h_a  Europe
h_a's Avatar
C'mon! You need thermal coupling, otherwise your matched fets are going to drift thermally -> they're no longer tightly matched.
That's the reason the 2SK389 is a double package, tight thermal coupling and best matching since both fets are sitting next to each other on the wafer.
Don't worry about glueing them together. It would be nice todo if possible, but if you don't need the last bit of performance (then the 2SK389 would anyway the only choice) put them in and that's it.
Cheers, Hannes
High Octane phono preamp Wiki
Old 22nd July 2007, 12:48 PM   #5
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
fun stuff, watch the production date code : here
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 25th July 2007, 03:46 PM   #6
h_a's Avatar
Oh Jacco, excuse my ignorance, but I fail to understand the production code. The datasheet also gives me no clue about what '7E' might mean.
Struck the lightening please. Cheers, Hannes
Old 25th July 2007, 03:53 PM   #7
twitchie is offline twitchie  Burkina Faso
Is that supposed to mean they were 'produced' in 2007?
I guess if they're fakes, it would be true, since they probably were made this year.
Old 25th July 2007, 04:03 PM   #8
uli is offline uli  Austria
Bought lots of SJ109 in 2004 - 2005, some of them carry 7E
does not mean 2007
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 25th July 2007, 05:18 PM   #9
NEW/NEU ones from May '97.
Old 26th July 2007, 08:48 AM   #10
h_a's Avatar
Isn't it the same for Jfets as for wine?
The older it gets the better it is
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109?Hide this!Advertise here!
wanted 2SJ74's or 2SJ109's audiodan Swap Meet 0 13th April 2009 11:17 PM
2sk170, 2sj74 enzedone Parts 4 21st December 2008 06:38 AM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 10:26 AM
What about 2sk369 in place of 2sk170 in MC phono patriz Pass Labs 2 24th February 2003 11:35 AM
2sk389, 2sk170, 2sj74 in Europe? patriz Parts 16 6th December 2002 01:28 PM
Copyright ©1999-2017 diyAudio
