Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
how is the quality of a chip-based volume control VS normal stepped attenuator?
Old 16th July 2007, 01:46 AM   #1
jarthel is offline jarthel  Australia
Default how is the quality of a chip-based volume control VS normal stepped attenuator?
as title.
the stepped attenuator is using Dale RN55/60 resistors. the chip-based pot is using pga2310.
thank you
Old 16th July 2007, 07:05 AM   #2
Calvin is offline Calvin  Germany
Calvin's Avatar
it depends what You understand under ´Quality´
Sonically I ´m still wondering why suddenly silicone R´s as used in a PGA should be good, when otherwise No one uses these when it comes to building with discrete part?
And than are there OP-gainstages when You don´t need them. Why should that be any good for sonics? TI claims they use ´high performance OPs´ but looking at their Datasheet there isn´t much that could be rated high performance after nowadays SOTA.
Physically the PGA maybe the better part. Its smaller, less part count, less soldering, etc.
With regard to costs the PGA is better too. You´s have to invest in quite many first class relays to get a similar number of volume steps with a discrete switched attenuator.
I personally still stick to good Rs and good Relays..and to good sound
jauu
Calvin
Old 16th July 2007, 10:18 AM   #3
Nordic is offline Nordic  South Africa
Nordic's Avatar
http://pedjarogic.com/spot/index.html
Old 16th July 2007, 12:15 PM   #4
float is offline float  England
This is my thinking too. But...... in practice a PGA 2310 can sound surprisingly close to SOTA when used with good regs; dynamics and transparency are particular stand-outs.
It probably is due to short path and lack of physical switch contacts. With steppers the switch matters as much as the resistors...
I w isH i cuold typpe bettr
Old 16th July 2007, 03:40 PM   #5
thanks for the replies.
may I ask what is meant by "SOTA"? thanks again
how is the quality of a chip-based volume control VS normal stepped attenuator?Hide this!Advertise here!
www.diykits.com.hk stepped volume control ... any good? kvk Parts 19 23rd April 2008 09:10 PM
PLLXO with stepped volume control? Dartagnan Multi-Way 8 6th October 2004 05:17 PM
volume stepped attenuator idea Jamh Chip Amps 22 26th April 2004 04:14 AM
Volume Control via logrithmic stepped attenuator PaulHilgeman Solid State 4 6th February 2003 12:51 PM
Gainclome Volume Control using Log Stepped Attenuator PaulHilgeman Parts 10 5th February 2003 09:40 PM
Copyright ©1999-2017 diyAudio
